Old 09-14-2006, 02:02 PM
Vices Vices is offline
97 Taurus Transmission
I have a 97 Taurus with the 3.0 engine and AX4N tranny. The transmission recently started slipping like the car was in neutral. It doesn't do it all the time though. Today it started this slipping about the time I turned the A/C on. When it runs, it runs good. It just occasionally slips like it's in neutral. It seems to work OK when I shift to low. Another note, related or not, is the power steering seemed to quit about the same time. When I turned the A/C on, the tranny and steering both quit. After I parked the car, shut it off and restarted it, everything worked fine. I know there's an aluminum piston in the tranny that can cause this problem, but are there other possibilities? Can all of these problems be anyway related? The car has about 83,000 miles on it. Thanks!
Old 09-14-2006, 05:48 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 97 Taurus Transmission
Welcome to the forum!
Does the A/C seem to work just fine when the power steering and transmission seem to have problems?
Is there a chance the belt is slipping when you turn the A/C on, the alternator stops providing current, and the battery is weak so electrical features stop functioning properly (such as electronic transmission controls)?
Have you pulled the tranny dipstick and checked the level and condition of the transmission fluid? If not, do so and reply here as to it's condition (color, smell, any sparkly flakes, etc.).
-Rod
Old 09-14-2006, 06:00 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
After following Rod's advice, have the Transmission Range sensor checked also. This thing, in Ford's wisdom, has grounds for a lot of things run through it. It is relatively inexpensive and easily changed.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 09-14-2006, 09:52 PM
shorod's Avatar
SHO No Mo
Ahhh, yes, I forgot about the TRS. Good suggestion!
-Rod
