Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 09-14-2006, 11:50 AM
Chiquae07's Avatar
Chiquae07 Chiquae07 is offline
Send a message via AIM to Chiquae07 Send a message via MSN to Chiquae07
Quick neon question for a friend
Hi. My friend currently owns a 1999 2.0 sohc neon. He was wondering if it was worth just changing the head gasket for about 400 bucks since thats all it needs, or drop in a new engine. i say head gasket but he his stuck on the engine swap. any suggestions?
2008 Mazda 6 ATX 2.3 Liters of Slowness
For those 9 seconds it takes me to reach 60mph, will be the most fun ill have in this car.
Old 09-14-2006, 12:01 PM
neon_rt's Avatar
neon_rt neon_rt is offline
Re: Quick neon question for a friend
If he is going to swap in an engine, have him change the head gasket and timing belt before he installs the engine, so he won't have to until much later.
Old 09-15-2006, 07:51 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Change the headgasket and might as well do the timing belt, water pump, and tensioner pulley at the same time since it will all be apart. If he is close to or over 100,000 miles he needs to do that for preventive maintenance.
2003 Dodge SRT-4
Old 09-15-2006, 08:34 PM
Chiquae07's Avatar
i believe that he said that he would have his mechanic do it for him, since he doesnt have the time to do it...makes no sense right? instead of 30bucks, its 400.....
on a second note, i believe he has about 91k on his engine, so those would probobly would be the best things to do. i am not that well known about neons, so i asked. anyother things should he look out for to to go bad around 100k?
