Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 09-14-2006, 09:48 AM
boomboom boomboom is offline
97 V6 Camry Spark Plug Replacement
How do you change the back three spark plugs on a 97 V6 Camry? Do you have to pull off the fuel injection unit?
Thanks.
Old 09-14-2006, 01:01 PM
xfeejayx's Avatar
xfeejayx xfeejayx is offline
Re: 97 V6 Camry Spark Plug Replacement
lots of patience, lots of fittings. or yes, you can take the intake manifold off. No matter how you do it, it's a frustrating job to tackle . Remember to use Ngk or Denso plugs, and you might want to just put the iridium plugs in so you never have to worry about it again. Don't waste money with the dual electrode pugs, Toyota doesn't recommend those anymore. Stick with the single electrode (and save $7 a plug).
Old 09-14-2006, 01:37 PM
sr20dk sr20dk is offline
i always use denso's at my shop, they are oem, they also make iridium, changing the plugs isn't that bad, you just need the right flex joint & extensions and a mechanical knowledge, not easy for a novice\
drew
Old 09-14-2006, 09:02 PM
AccordCodger AccordCodger is offline
Save 7 bucks a plug? Where do you buy yours? I bought 4 dual-electrode NKGs for about 8 or 9 bucks at the beginning of this year.
