Old 09-14-2006, 03:27 AM
blk92sl blk92sl is offline
what is possible?
ok, i just want to know what you guys think is possible with this setup... (as far as HP/TQ)
8:1 engine newly rebuilt, Dynamic Racing street grind cams, Dynamic Racing high-rev springs, 15gs, 550cc injectors, hotwired walbro 255, SAFCII, datalogger, full turbo back exhaust, intake, and a bunch of other stuff but no real power boosters...
1992 Black 3000gt SL
-Pivot sleepy-eye headlights
-Valentine One radar/laser detector
-K&N FIPK w/ removed resonator
-Custom downpipe-back true-dual exhaust
-Topline Engineering Ground Wires
-Front Strut Bar
-Intrax Lowering Springs
(pics coming soon)
Old 09-14-2006, 05:41 AM
Gateway's Avatar
Gateway Gateway is offline
Re: what is possible?
i would say anywhere between 1 - 500 HP. The reason for the big range, is because the TUNE is the most important element. All those mods + a bad tune = crappy HP. Make sure it's tuned good.
'92 3000GT VR4
Current Mods:
K&N FIPK
RPS Streetmax clutch
Rebuilt tranny
Free Boost Mod
Maximal Performance Solid Motor Mounts
Pictures and Videos of my car
Got a question about your auto insurance? I'm an insurance agent, ask away.
Old 09-14-2006, 12:49 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
is this setup supposed to be for a daily driver? if so, you're in for a treat...when you upgrade cams on a car, you lose vacuum from the intake b/c of the increase valve overlap. as a result, you have little to no vacuum boost when braking, so you'll have to stand on your brakes everytime just to bring the car to a normal stop.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 09-14-2006, 12:50 PM
Morphius289's Avatar
Morphius289 Morphius289 is offline
If you're buying a new block, just get one of Rays 3.7l stroker kits.
Black 1997 3000GT
Originally Posted by Igovert500
[01:05] Igovert500: scrwe his method
[01:05] Igovert500: too much crap
[01:06] Igovert500: i just jam a garden hose in there
[01:06] Igovert500: and put it on high flow
[01:06] Igovert500: go the opposite direction too
[01:06] Igovert500: so it clears out more shit
18 and out of debt - member #1
Old 09-14-2006, 01:04 PM
Linebckr49's Avatar
but the 3.7L stroker kit would cost as much as the block!
93 3000GT base
Old 09-14-2006, 01:12 PM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Street cames will most deffinatly not have that effect.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 09-14-2006, 01:58 PM
Linebckr49's Avatar
so what amount of overlap gives that affect?
is it based upon amount of overlap? or is it also dependent upon the engine and how much vacuum you normally have on stock cams? i would think its a matter of the brake booster, how much vacuum is required to operate it normally, and minimum required for normal operation.
reason i chimed in b/c a friend of mine recently got his 94 rt/tt back from the builder. he has cams in ( not sure what kind/grind, but now i'll have to ask) and he has no vacuum for braking.
93 3000GT base
Old 09-14-2006, 02:47 PM
2old 2old is offline
Did he upgrade the turbos?
The manifold vaccuum should always be present when the turbos are idling (0 boost) no matter what the cam overlap otherwise the the engine would die at idle...
I think he might have a vaccuum leak somewhere because the vaccuum formed at idle should be stored in the vaccuum canisters (this might not have been an issue before b/c stock turbos with stock BOV and wastegate might be removing the boost fast enough to from a vaccuum for the brakes when he got off the gas).
