alcohol on my sl?
my question is, is it safe to run an alcohol injection system on my sl, if so what sytem is useful?? i dont wanna blow my rings. will i need a begger pump?? can my engine handle it. its pretty stock, just intake exaust, no biggie. i mean if it can handle tt then it should handle alcohol right?? plus what r the hp gains?? thanks
'94 3kgt SL -ebay intake (why not) -2 1/2 inch straight pipe exaust, custom y downpipe -Ignition mods -dual magnaflow exaust -going TT (wish me luck) black book -'95 mustang v6 (modded) ///// -'00 neon (modded/non-turbo) /// -'04 eclipse GT -'05 eclipse GT (modded) -'97 Prelude vtec (modded) -CRX (modded) -Mazda Miata mx5 // |
Re: alcohol on my sl?
Be a man. I run 100 proof Jack Daniels.
Black 1997 3000GT ![]() Quote:
haha no really, is that a good idea?
A quick answer- no. Just spray it.
why in the world do you want to run an alky system on your NA?
do you even know the purpose for running one? the systems out there are all the same: their purpose is to prevent pre-detonation and by cooling the intake charge....on Forced Induction engines. these systems use water, methanol, alcohol. they are NOT POWER ADDERS, but power protectors. you have no need for this on your SL. if you want a power adder, get N2O.
93 3000GT base K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2 coming soon: adj. cam gears | bi-xenon HID retrofit |
![]() just run 93 octane and you shouldnt have any issues whatsoever with knock. |
If you have no turbos, 93 wont help, and alky wont help. I suggest a wetshot of n20
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
