Old 09-13-2006, 10:05 PM
LilRedBoTie LilRedBoTie is offline
Rear View Mirror Switch
There was a guy a couple of posts ago about an '06 that someone replied to him that you could just switch out the base mirror that has the on/off air bag warning and put in one of the temp compass mirror. Now will the same thing work on an '03 silverado or will I have to get some sensors put in for it. And if I can just switch them out could I get a mirror at a salvage yard or where could I get one? I would appreciate any help cause I have always wanted one of those mirrors but i thought it would be too much trouble to do and if i can just switch them out it would be great
Old 09-14-2006, 11:35 AM
mayito mayito is offline
Re: Rear View Mirror Switch
You will need the sensors too. I did the same thing and the compass does work but the temp. displays 0C.
Old 09-14-2006, 01:34 PM
Alright Thanks I guess there goes that idea. Oh well I will have to spend my money on some other mod that I want to do.
Old 09-14-2006, 01:38 PM
but hey, at least the compass works in case you get lost. Its helped me several times. haha. Also, i got the one with the onstar buttons and it looks better than the original.
Old 09-14-2006, 04:43 PM
Ya thats true it would look better than the original. I'm trying to get all the stuff to make my truck look like one of the high end trucks because it is just a base model. I might just end up getting one anyways. Can yo get one at a scrap yard you think?
Old 09-14-2006, 11:17 PM
I got mine on ebay for $40 used, but since their inside their like new. Yeah my truck was too a base model. But right now i have everything that the v8's have including a v8 p/w, p/l/ p/mirrors. I just need seats and carpet!
Old 09-14-2006, 11:33 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Wouldn't it have been cheaper just to buy a better truck? I like your wheels, though; I want a set
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 09-14-2006, 11:47 PM
Well when i got the truck in 2003 when they first came out the v8 cost about $30,000 plus tax, etc. Mine came out to $20,000. I've spent about $2,500 to make it into a v8. The only way you will know it was a base model is because of the seats and carpet, but i plan on changing those too. But other then that its all the same.
Old 09-15-2006, 07:07 PM
vnotaro vnotaro is offline
I did this a while ago on my '01. The wiring harness was tucked into the headliner. I don't have OnStar and there are a few different models of mirrors with different plugs. See if you have a plug up in the headliner and then just get the mirror thats right for that plug. You will need to get a temp sensor. They can be found cheap on ebay. The whole install took me about 40 minutes and cost me less than $75. I got lucky on ebay for a brand new mirror. My wife thought I was crazy but now she wants one for her car.
Old 09-16-2006, 10:08 AM
Ya i've done most of it to. I have the wheels p/l keyless entry. I dont have power windows yet. or cruise control. My next project is too put a V-8 in it. I should be getting a raide pretty good raise pretty soon so I am going to try to put a 6.0 in it. Then it will be a bad truck. My fiancee wont be happy about it but she said i could
Old 09-16-2006, 11:50 AM
Great man, and go with the 6.0 cause now i regret getting a 5.3 instead of the 6.0. Its a great feeling seeing the before and after of the trucks and how much they have changed,all the time and money spent on them. My gf gets mad at me all them time cause i spend my money on my truck, rather then other important stuff! But i don't care, to me its all worth it haha
Old 09-19-2006, 07:59 PM
You regretted putting the 5.3 in it? the only problem is i have to find a way to get the money saved up. I think I should be able to in about 6 or 7 months hopefully. And that sounds just like my fiancee. But oh well a boy has to play with his toys.
Old 11-02-2006, 10:32 AM
ckjy2kusa ckjy2kusa is offline
Question Re: Rear View Mirror Switch
Hi,
I just change my '07 (03-07 are the same, except the all new '07) to auto dim rear view mirror w/compass work, but not temp! I know I need the sensor, but where and how do I install them?
On my connection in the mirrow, there are 16 pins, but only 4 wires connected (other w/on star get 12 wires connect).
How do I connect the temp sensor from outside to the rear view mirror connection? let say if I found the temp sensor.
Old 11-29-2006, 11:54 AM
Re: Rear View Mirror Switch - Found It
Originally Posted by ckjy2kusa
Hi,
Thank you all!
I have found the temp sensor at a junk yeard for FREE, and install it in my 2007 Silverado (03-07 are the same, not new '07).
It's pin 5 (positive) & 6 (negative) in the plug.
It works great.
SILVERADO OLD 2007
Old 12-01-2006, 12:01 AM
Thank you all!
It works great.
What else did you get? the wiring from the sensor too??
