Go Back   Automotive Forums Car Chat > Buick > Regal
Old 09-13-2006, 09:03 PM
DJPsystems DJPsystems is offline
torque convertor lockup problem
I have a 96 Buick Regal 3.1 with 106k on the odometer. When driving on the highway at speed 65 and over, the lockup will not work. I can tell because of the rpms don't drop slightly. Then I get a check engine light with code 1870. I was wondering if anyone can shed some light on this?
Old 09-14-2006, 12:58 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: torque convertor lockup problem
DTC P1870 in a 4T60E transmission is a Transmission Component Slipping fault. Excessive TCC slip has been detected when the torque convertor should be engaged.
When was the last tranny service performed. ATF and screen filter?
Timeslip 08/12/06
AF Community Guidelines
Old 09-14-2006, 12:59 PM
I recently changed the fluid and filter, the old fluid did not look too bad. This problem hapens after about 10 minutes of highway driving.
Old 09-16-2006, 09:37 AM
troy1 troy1 is offline
AF -Advisor
the bad news 96's were terrible at loosing converters. The converter has more than likely gone south.
Old 09-21-2006, 12:50 PM
Mrbizness1 Mrbizness1 is offline
You can unplug the comverter or pull it's fuse if it has one, and still use the car as you normally do. You will use a little more fuel but it won't do any damage to the vehicle. I drove a Olds for 75k miles with the converter unplugged.
Old 09-21-2006, 03:57 PM
BNaylor's Avatar
His Regal has a 4T60E RPO M13 autotransaxle. You cannot pull a fuse for just the torque convertor without losing all shifting.
The TCC lock/unlock commands go through one umbilical connector. Again, removing it will disable all shift functions not just torque convertor.
His torque convertor is not locking so I do not know what good disconnecting it will do. It sounds more like a valve body related problem with the TCC or TCC-PWM solenoid. It would be different if the torque convertor was constantly engaged, then trying to disable it would make sense.
Timeslip 08/12/06
Old 09-21-2006, 05:21 PM
ricebike ricebike is offline
did you clear the codes/reset the ecu/ecm/pcm? just to see if the code will return?
easy to do & worth a try <shrugs>
Old 09-22-2006, 11:25 PM
problem solved!!!
One thing I noticed that the problem occurs when the tranny is hot. I had an external cooler but I guess it was not doing its job. So I went to the junkyard and I set out to find the biggest tranny cooler that I could find. I ended up finding a small ac condenser about 22"x12". I flushed it out and cleaned it up. It was awkward fitting it in but I hooked it up. Then I took a long drive about 300 miles on the streets and freeways and the lockup worked like a charm .... at least for the moment. I have no clue as to how long it will work, who knows. At least I learned something.
Old 09-23-2006, 04:34 AM
I would scan the codes and clear the codes with the my actron scanner but they would allways pop back up. I just wonder how long this tranny will last.
Old 09-23-2006, 09:18 AM
BNaylor's Avatar
You've got nothing to lose at this point in time since it looks like a solid problem but have you tried any tranny additive? Lubegard or Seafoam?
Also, find the tranny umbilical cable. Should be at the top of the driver's side of the tranny. Remove it. Check for corrosion, etc. and then reseat.
Timeslip 08/12/06
Old 09-23-2006, 10:55 AM
AF -Advisor
around town it can last for a while but get out on the hiway using OD on a hot day its just a matter of time. like I said earlier 96 was a bad year for TC on GM cars they always seem to fail.
