Help! Need Engine Diagnosis
ok, I was wandering if this forum could help me diagnose an engine problem to my car. I drive a 97' 3ooogt sl with 80000 miles. For the past two weeks i have been noticing a problem. When i start my engine up, for a couple of seconds, my engine sounds like it is running with no lubrication. It doesnt give the pur soiund like an engine should. After about 3 seconds this goes away and the car is back to flawless. Drives great and doesnt make any other noise except at the start. The longer i go without driving the car, the longer the noise lasts at startup. sometimes it may last up to 10 seconds. this noise only happens after i leave the car for a period of time. anything longer than 2 hours or so. Once again the noise sounds like the engine running with no purring sound or lubrication. Also the oil light pops on while the noise is going on...then cuts off when the noise stops. My oil is full and i have put an additive in since the problem and it didnt help. If anybody has any clue to perhaps what this may be, I COULD USE THE HELP!!! LOL ...tks for your time
I wish I could help you man, but you might have a better shot at www.3si.org at getting one of the real tech heads on these cars giving you some answers. Good luck.
Resistance Is Futile (If < 1ohm) |
I HAVE A 1992 VR4 WITH 88000 MILES AND THE EXACT SAME THING HAPPENS WITH MY CAR. ?????????? I DONT KNOW WHAT IT IS. IT KIND OF SOUNDS LIKE DETONATION OR TICKING. ITS WIERD.
hey
i sold that car a long time ago....ended up bein the fuel pump. i now drive a 95 vr4. your ticking could eithor be lifter ticking or check to see if your oil gauge is low.....if it is then u may need a new fuel pump.....if that fuel pump is bad and doesnt get changed you could spin a bearing which would cause severe engine damage......but most likely it is lifter ticking.....are u a member of 3si.org?
IM NOT A MEMBER OF 3SI. I BET ITS A PAIN IN THE ASS TO CHANGE THE FUEL PUMP. I HAVE ARC 2, SO I DIDNT UPGRADE MY FUEL PUMP. I GUESS NOW WOULD BE A GOOD TIME. WHAT DO YOU RECOMMEND?
fuel pump
the top 3 for our cars in order are:
1)supra fuel pump 2)walbro fuel pump 3)denso fuel pump the supra is best all around.....flows great and only costs 180 http://www.partznet.com/mitsudsmclub.html[u] walbro is good and only costs 100....doesnt flow as well as the supra pump but u can't go wrong with it denso flows ok but is a little pricy u should join 3si.org......thousands of members, 3000gt gatherings, and its by far the best forum for our cars
To be honest it just sounds like your oil is taking it's time to pump through the engine. Is your car out in the cold or anything like that?
As for the fuel pump, it's not hard... requires about the same mechanical ability as changing your spark plugs.
'91 VR-4 - not running '02 Hayabusa - winter storage '03 WRX - running ![]() Click here for my site and 1:24 car pics! |
Recently I have noticed as it gets colder my car ticks more. The colder the more it happens. It only happens late at night when I drive home from work? Weird huh! can y0ou guys explain that?
Ok thanks. Will it hurt the motor? I have a feeling this is bad. what do you guys reccomend me to do? Your responses are greatly appreciated.
Lifter tick will not cause damage to your engine. Of course if its rod nock then you're screwed. However, considering everything you've described, its 99.999999% likely that its lifter tick.
To help eliminate or nearly eliminate the noise do the following. Its worked for me and for others with no side effects. 1 - qt Engine (Motor) Flush. 1 - qt RISLONE engine treatment. 4 - qts Castrol GTX 10W-40 Oil 1 - OEM or better Oil Filter. 1 - PCV valve *possibly 1 extra oil cap gasket. Run engine til warm. Put in 1 quart of Engine (Motor) Flush. Run for prescribed time (normally 8 minutes) Drain oil/flush til completely empty. Remove old filter. Pre-charge the new filter with RISLONE. *replace drain plug and poor in the rest of the RISLONE. Fill to top mark with the GTX. Replace PCV. If your oil cap leaks, add another gasket or replace cap. Give it a 100 miles of so, you should see a marked improvement, if not complete success. You will need to repeat this process every 2500-3000 miles (change filter every other time). You can cut back to 1/2 qt RISLONE.
Hey thanks a lot! When I get time I will try that. Hopefully it will work. Hey what have you done to the Spyder? In my opinion that is the best car ever made. Hopefully when I get older I will own one. When I get enough money. I am very jealous(spelling?) I have never seen one in person, but if I do I will cry!!!
The Spyder has no cats (the main has a straight pipe and the precats are gutted. Borla exhaust. K&N open air filter. Under drive pulley. Blitz boost controller. 550 injectors. Sometime I might put some lowering springs on the car, but I'm still up in the air about that.
