96 Check Engine light on
I have a 96 LeSabre and the Check Engine light is on. It has about 101k on it and I am the second or third owner. Other than the light, there are no visible or audible problems that I am aware of. I called a local mechanic who has worked on this car in the past and they want $85 just to run the codes & diagnose the problem. I have put more money than I want to in this car already having recently done the plenum and upper and lower gaskets. Any thoughts would be appreciated.
Re: 96 Check Engine light on
Thanks. I will give that a try.
I took it to Autozone and the code came up P0442 which apparantly has somthing to do with the EVAP system. One of the suggested fixes for that code is a new gas cap. I don't think that is the problem. I think it is probably one of the hose/tubes for that system, but I am not a mechanic. Maybe when they fixed the gaskets they "pinched" a well worn hose that needed replacement anyhow. My son and I plan to dig around the engine hoses this weekend and look for leaks that we can see.
Just a thought.
There may be a hose in the wrong place. I understand that emission system is a gas vaper purge maybe problem is control valve wires. The system waits till the engine has been running for a while and purges the vapors back into the intake. Not sure the PCM knows theres an actual hose leak, just a control line off. Gas cap is a one way gas vapor valve. I suck on em' working. (not good but works) Good luck |
Thanks. I will take a look and see if I can spot a hose problem.
I had problems with my engine check light coming on and off also. It was the upper manifold problem. I had this fixed then the MAP sensor went out on me and this made the light come on also.
Am holding out to have this fixed. Now I have a water pump leaking and have to get this fixed or I won't have an engine. www.gotenergy4u.com
Looking for a slender full blooded Chinese girlfriend. |
