Old 09-13-2006, 06:44 PM
AutostradaVR4 AutostradaVR4 is offline
Brake Fluid Capacity?
i did a quick search on the web/stealth316/AF and couldnt find it. Does anyone know how much fluid our brake system holds? My brake stuff is en-route so i was gonna buy some Motul RBF 600, but dont know how much im going to need.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 09-13-2006, 08:36 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Brake Fluid Capacity?
very good question. i searched/asked the same question on 3si when i was installing my SS braided brake lines. our system holds less than 3 pints (12 fl. oz. per pint, IIRC). so if you get 3, than you'll have enough in case you spill some. but you'll probably use all 3 pints, or close to it, b/c you'll want to bleed the entire brake system (since its probably never been done for the life of your car) and put new fluid in.
i heard speedbleeders suck. just have a friend help you bleed the system. work one caliper at a time.
by the way, what brake stuff did you end up getting?
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 09-13-2006, 08:51 PM
I actually found a much cheaper way out than the list i posted previously. I found a company called iRotors. They sell stuff mainly on eBay, but you can buy from them directly over the phone, too (which is what i did.)
I got Axxis Ultimate ceramic pads, SS braided lines, and zinc plated drilled/slotted rotors for $444 shipped. I forget what company they said they got their rotor blanks from, but i did recognize the name. I'll have to ask them again.
theire web site is here: http://www.irotors.com/products/16-1.shtml
anyway, thanks for the info!
Formerly BlinkRA182
