Tires
Does anyone know what the largest size tires that will fit on a 2001 Yukon XL 4x4 without rubbing? I don't want anything to massive just a little bit larger than the 265/70 16's. If anyone has any pics those would be greatly appreciated.
Re: Tires
Try tirerack.com for oversize info.
Re: Tires
Might could get away with 285x75x16. Maybe 305's. Will need to re-program speedometer and ABS.
Re: Tires
I went to tirerack.com and all I could find was the stock size. Am I missing something?
Re: Tires
I know you can recalibrate the speedometer, but I don't think you can reprogram the ABS or need to. |
Re: Tires
I have an 03 4x4 Tahoe and the same question. From what I understand, you can go with 265/75 or 285/75 on the stock 16" rim. Try a search on the Silverado forum, a lot of people run 285/75s on their Z71s.
I've heard where the 285/75s will rub when the steering is hard over but then some say they don't have that issue. Likely it depends on which tire you choose. The 265/75s don't seem to be an issue and I think they were an option on the Tahoe/Yukon lineup...probably your best bet. Below are links to some pictures of Tahoes with the 285/75/R16s. I couldn't find any with 265/75s but maybe someone here can add some. http://www.cardomain.com/ride/770448/1 http://www.cardomain.com/ride/654776 Last edited by east302; 09-15-2006 at 01:56 PM. |
