Old 09-13-2006, 05:19 PM
derekbitt derekbitt is offline
grinding noise ???
have a 1998 z71 k1500 that i have inspected the brakes on and they are all perfect.....that being said, intermitantly I get a grinding noise that seems to be coming from the front brakes only when i brake at slow speeds to a dead stop,, but only some of the time. I cant tell exactly where it is coming from, and it is really driving me crazy. also , when i first start driving it doesnt seem to happen but after a few minutes into driving it starts. it has been getting a little more apparant over the past 6 months..
someone please help,
DB
Old 09-14-2006, 07:57 AM
Blue Bowtie's Avatar
Registered Offender
Re: grinding noise ???
Are the calipers floating freely on the brackets/pins? Were the caliper pistons clean or pitted/corroded when they were removed for inspection?
If you drive on gravel or loose stone roadways, there may be sand, pebbles, or other contamination in the pad areas or causing the caliper to stick. I saw a trailer light connector lodged in a caliper bracket once, binding the caliper and causing pulling from the opposite side. Strange things can get in there.
Old 09-14-2006, 02:23 PM
alblogg's Avatar
alblogg alblogg is offline
I agree it might not hurt to tear them down and see if there are any debris pebbles or just a sticking caliper.
'99 Blazer LT Loaded, K&N Filter, Pioneer Super
Tuner,Viper
'98 Pontiac Grand Prix GT, 3.8
'88 K1500 Cheyenne, 5.0, stock, bought new
'86 Nissan 720 Trash Truck
'69 C/10 step side, 307, all original, second owner, in process of restore.
The person who says it cannot be done should not interrurt the person doing it.
Share your knowledge. It is a way to achieve immortality.
Allen- Paintman
Wrenchtwister
Broompusher
Old 09-14-2006, 04:19 PM
i did tear down both front brake assmblys, the calipers looked good and floating, the pads had some surface cracks in them. I went offroading a couple weeks ago and did get into a lot of water, maybe that got the pads screwed up. any ideas?
thanks in advance
Old 09-16-2006, 12:30 PM
horse482's Avatar
horse482 horse482 is offline
AF -Advisor
Cracks in the pads will cause noise.
NO 4 N JUNK
1994 GMC K1500 XC 5.7L
2008 Chevy Impala LTZ
Old 09-16-2006, 01:05 PM
Thanks Guys-
I Took The Assembly Apart Again And Looked At Them Closer, Both Sides This Time. On Both Sides The Cracks In The Pads Were Obvious And The Pads Also Looked Burned. I Changed Them Out, And It Stops Smooth And Quiet Now....those Old Pads Are Going Back To The Store For A Refund (2 Yr Waranty)
Thanks For The Replys
Bitt
