Old 09-13-2006, 03:10 PM
bigry2004 bigry2004 is offline
Send a message via AIM to bigry2004
Heater not working..
I have a 97 s10 blazer. About 2 years ago, before winter i had a problem with pressure, along with actual heat coming out of my system. i put in a new heater core, as big of a pain-in-the-ass as it was, and everything was fine through the last two winters. I had a radiotor problem last week, had a new radiator installed, and since returning from the shop, have no heat. Pretty good pressure, but no heat. I took off the heater hoses and ran water through them to see if something was clogged, but still no heat. Could it be something else with the heater core? Or possibly something simple like the thermostat. Much appreciated.
1997 Blazer LT 204k miles, 4X4, BF Goodrich AT's, 2 Pioneer 6x9's, 12" IMPP subwoofer with 1000watt Pyramid Amp. CAI.
Old 09-13-2006, 03:13 PM
alblogg's Avatar
alblogg alblogg is offline
Re: Heater not working..
where is your temp gauge running?
'99 Blazer LT Loaded, K&N Filter, Pioneer Super
Tuner,Viper
'98 Pontiac Grand Prix GT, 3.8
'88 K1500 Cheyenne, 5.0, stock, bought new
'86 Nissan 720 Trash Truck
'69 C/10 step side, 307, all original, second owner, in process of restore.
The person who says it cannot be done should not interrurt the person doing it.
Share your knowledge. It is a way to achieve immortality.
Allen- Paintman
Wrenchtwister
Broompusher
Old 09-13-2006, 05:24 PM
My temp gauge is running about normal between 150-180. I even let the car heat up for a while with still no heat. Since i flushed the two heater hoses, i've not driven it a long distance. I will turn it on tonight when i get to work to see if it is working. Until then, any other suggestions/ideas?
Old 09-13-2006, 06:07 PM
Teal95Jimmy's Avatar
Teal95Jimmy Teal95Jimmy is offline
Send a message via AIM to Teal95Jimmy
There may be air still trapped in the heater core. Burp it and see what happens.
Old 09-13-2006, 08:29 PM
rhandwor rhandwor is offline
Their is a heater valve for these units in the bottom of the case this is a damper it has a vacuum operator.
Their should be a dial in the dash which turns from heat to def or ac. They sell them at the dealer. You can use a vacuum gage to determine if you have vacuum. Check the vacuum at the engine I have found this fitting plugged and had to remove and clean it. Normally it has a few branches for a few lines.
With the temperature you stated I don't understand how your engine is operating effeciently because it is like operating with the choke on.
I had a customer who was getting about 3mph because he was operating about 150 deg. A new 195 thermostat jumped his gas mileage back to I assume around 12-15 mph.
Old 09-13-2006, 08:47 PM
alblogg's Avatar
Could your door not be opening and closing? Stuck on the cold side.
Tuner,Viper
Allen- Paintman
Wrenchtwister
Broompusher
Old 09-15-2006, 07:52 AM
BlazinMlew's Avatar
BlazinMlew BlazinMlew is offline
Send a message via Yahoo to BlazinMlew
Sounds like the themostat to me. I have a bad one as well. I say that because I belive you should be running 180 to 195. not sure but 150 to 180 sounds a little low unless you have that temp. themostat in there. Gently touch your upper radiator hose after you have driven for a while. If it's cool then you know you have a problem. (I am not sure if that is an actually good diagnosis but I have heard people say to do it)
2000 Blazer 4WD 2Door
http://www.cardomain.com/ride/2324297
06 Pontiac G6 V6 Coupe
http://www.cardomain.com/ride/2371527
Old 09-15-2006, 12:35 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
150-180 is pretty cold.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 09-15-2006, 03:00 PM
hmm thanks for all the suggestions guys. yeah, it does seem to run a bit cold. but also i thought, because i had the heat cranked and the two heater hoses going into the heater core werent really getting warm, that there was somethin clogged. but im not sure.
Old 09-15-2006, 07:38 PM
When you change the thermostat vent out the system or jack up the front end. After it is running at operating temp.shut it down and refill when cold.
Lack of anti freeze will also cause a cold car. They only other time I saw a car use this much fuel was caused a crack in the exhaust manifold by the O2 sensor. Just like smoking 3 packs a day.
The computer doesn't start working properly until around 190 degrees.
The S-10 I was talking about was a throttle body and the customer could notice it pouring gas into the car. I had a otc4000e tester and watched the temp when driving. If you have plenty of gas money you are still causing pollution.
Old 09-15-2006, 08:06 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
It sounds like you're running no thermostat. I'd do what the others are suggesting and run a 185-195 degree one. Also, check the valve in the heater hose to make sure there's vacuum at the line when the A/C is set to heat and the engine is warmed up. There's a chance the valve might be closed and not allowing water to circulate through the heater core.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 09-19-2006, 10:58 AM
I replaced the thermostat with a 195 degree one. There still is no heat however. I don't necessarily think it is a vacuum problem but just the fact that it is clogged up. There was so much sludge and nasty gunk up in the hose where the thermostat was and even some in the rad cap that it is possibly causing a clog up somehwere in the hoses or heater core? I guess i'm down to one last option i think, which is a complete flush. Also, i heard Prestone makes a good system flush that might clean that out of there. Any more suggestions?
Old 09-19-2006, 02:01 PM
The good flush came in a can with two parts. One for a flush one for a neutralizer when done . I would try and find a old parts store with some of this cleaner. Any new product is EPA rated and doesn't work as good. First I would remove the thermostat and put a tee in the heater hose open the drain and flush with a garden hose on a gravel drive after you drain the anti freeze. It is poison don't have your dog around. Don't overpressure the system. Also flush your heater lines. Garages are regulated and use a power flush system and disposal. Probably around $60 to $80 for this job.
Old 09-21-2006, 10:21 AM
alllright. i went to a radiator shop about 5 miles from here and the guy said he can blast 140lbs of pressure through there and knock anything out. He also said that chemical flushes arent the best cuz he ran into a blazer before with a head gasket problem that the chemical ate it away. He's charging me $45 so that might do the trick...
Old 09-21-2006, 11:48 AM
BlazerLT's Avatar
AF -Advisor
Just watch he doesn't damage your heater core with that high pressure.
