Old 09-13-2006, 11:15 AM
BlazayBlazerious's Avatar
BlazayBlazerious BlazayBlazerious is offline
I Need to Chill Out
Sorry for the bad title. Anyway, I need a new AC compressor. If anyone knows a good place to order one online, throw some links my way.
Thanks!
1998 Blazer LT 4X4
So stock it's got the
original oil in it...
well, not exactly
Old 09-13-2006, 11:45 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: I Need to Chill Out
Rockauto.com or ebay.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 09-14-2006, 09:25 AM
billibong's Avatar
billibong billibong is offline
I picked one up at the scrap yard for $75. It came with a 90 day warranty. Had to take the first one back, but the second one has been running great for almost two years.
Remember when you replace it to have the system vaccumed and also replace th oriface tube - that is kind of like a filter for the AC line as I understand it.
Also, when you have the system recharged make sure they include the oil that is required for the system, otherwise you wil be replacing the compressor again - shortly.
Good Luck.
billibong
99 4X4 Blazer LS Vin W
Repairs:
U/L Ball Joints, I/O Tie Rod Ends, New Tie Rod Adjusting Sleeves, New Idler Arm, R & L Front Hubs, R & L Upper CA Bushings, New Gabriel Ultramax Shocks (what a difference)
F & R Brakes and Rotors at 110,000.
Infinity Speakers to replace the blown factory sets.
162K+ and still kicking.
Old 09-14-2006, 10:43 AM
BlazerLT's Avatar
AF -Advisor
Yip, for sure have them use refrigerant AND oil, not just straight refrigerant.
Old 09-15-2006, 11:55 AM
JoulesWinfield's Avatar
JoulesWinfield JoulesWinfield is offline
I keep hearing about this "oriface tube" (orifice?). Where do you get one?
I have the same problem with mine. My compressor is starting to seize up.
Old 09-15-2006, 12:17 PM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
Should be able to get them at most BIG name parts stores.(Napa,Autozone,etc)
Example;
http://www.partsamerica.com/ProductL...Orifice%20Tube
It's my opinion, don't take it personal.
'04 T&C,'01 Blazer ZR2, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC
Old 06-21-2009, 08:42 AM
Allen7007 Allen7007 is offline
What exactly happens if the oil isn't added with the recharge? I got this done lately and now I need a new A/C compressor because it started leaking bad and it won't hold any refridgerant.
Old 06-21-2009, 10:03 AM
BlazerLT's Avatar
AF -Advisor
Any good shop will be able to put UV dye in and trace where it is leaking. Also, they usually should be putting a sealer in with the r134a to seal up the system. It might be something simple.
Old 06-21-2009, 05:04 PM
If youre system was low on oil it would end up burning up the bearings on the compressor. But, if thats the original compressor it could be more likely thats why it needed to be refilled to begin with.
