Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-13-2006, 12:22 AM
93_century_V6 93_century_V6 is offline
99 GT Fog Lights
I have a 99 Mustang GT 5 speed. The fog lights do not work on it. The switch does not light up at all. I pulled the switch to make sure it was plugged in and it was. Is the relay going bad for the fog lights a common problem on these cars? Thanks in advance.
Old 09-14-2006, 09:04 AM
jeff84red jeff84red is offline
Re: 99 GT Fog Lights
Make sure the connection up by the shifter is plugged in. I had the same problem. just lift up the console and check the wires. Also check the relays under the hood and check your owners manual for the location of all the fuses. There are more than one.
Old 09-07-2007, 08:58 PM
sUpamustang99 sUpamustang99 is offline
I have a very similar problem only the light does work on the switch but there is no power at the relays I have two and I tested them both with a volt meter. Anyone have an idea? And the High beams ar not on.
Old 10-16-2007, 09:46 AM
aaron69 aaron69 is offline
Cool Re: 99 GT Fog Lights
what i would do is remove the wires and install some new wires and a new switch. That is what i did to mine.
