Old 08-29-2002, 12:15 PM
hAnGoOkNoM hAnGoOkNoM is offline
Send a message via AIM to hAnGoOkNoM
The different types of putty
What are the different types of putty and their uses?
Old 08-29-2002, 12:38 PM
Jay! Jay! is offline
Horizontally Opposed
Originally posted by jay@af in AF Car Modeling FAQ - * Look here first! *
What is model putty for?
Fillers are used to hide gaps and to blend parts of your kit together. Apply it with a piece of card and make sure it is fully dry before sanding. Some fillers will only bond to bare plastic, others to only paint, so make sure you know what you are using.
If you are using putty which is Toluene based, apply some masking tape 1/16" - 1/8" on either side of the length of the gap, apply a small amount of the putty to the gap to fill it, remove the tape, then use a q-tip (or cotton ball) dipped in normal strength nail polish remover to remove excess putty just after it sets-up and starts to harden. Clean up any residue with a soft cloth. This will leave the joint perfectly smooth and you probably won't even have to sand it afterward!!
You can also use putty to build upon the plastic car body to form body kits and ground effects, etc. Epoxy putty is typically better for this use. Read more here: Tamiya Epoxy Putty help!
Hierarchy of Subaru:
(Click to see mine!)
