Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 09-12-2006, 05:12 PM
rchjr rchjr is offline
has anyone had trouble with fram oil filters
i was told my oil filter was to blame for my cold start problem
Old 09-12-2006, 07:01 PM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Re: has anyone had trouble with fram oil filters
I have heard bad things about Fram oil filters.. so I stay away from em.
I'd recommend you use Wix, heard nothing but great stuff from them.
Old 09-12-2006, 09:22 PM
2000blazerls's Avatar
2000blazerls 2000blazerls is offline
Yeah I would stay away from them too. I will try to find it but I read a report consumer reports did and they didnt filter worth a shit.
Bye Bye Blazer!
http://www.cardomain.com/ride/2159611
Hello Monte Carlo!
http://www.cardomain.com/ride/2445379
Old 09-12-2006, 09:30 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
I stay away from ALL their stuff... Nuttin' but bad..
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 09-12-2006, 09:55 PM
maxwedge maxwedge is offline
A990 racer
Question Re: has anyone had trouble with fram oil filters
Gotta ask, what is your cold start problem?
Old 09-12-2006, 09:59 PM
Is eating.
It was in his other thread.. he had piston slap so we told him to go back to using regular oil (He was using synthetic, a common problem, obviously) and also he thinks that the filter was causing the piston slap as well so now he knows a bit better.
Old 09-13-2006, 07:05 AM
The anti-drainback valve could've started leaking. That's a common Fram problem..
Old 09-13-2006, 07:38 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Piston slap is a common problem on the 3400 and it is not the Fram oil filter causing the problem. At least 75% of the 3400s I've worked on had it but it would go away after about 30 - 60 seconds of engine warmup. It is definitely annoying. According to GM it is not a problem. <---yeah right.
GM Piston Slap Info
Click here
Timeslip 08/12/06
AF Community Guidelines
Old 09-13-2006, 11:54 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Anyone that tells you that a Fram filter is bad (and is the root of your problem) is trying to sell you THEIR brand of filter. I've used them for years and have never had a problem with them. They still have to meet or exceed new car specs.
As long as you are using the correct grade of oil and change it regularly along with the filter every time, you should never have a problem with any name brand oil filter.
But do be aware some chain stores, also some big auto supply houses, carry "bargain" versions of otherwise reputable filter products. Sometimes the part number is slightly different or it is packaged differently. How else can they sell you a filter for $2 that normally goes for $6?
Bob
Old 09-13-2006, 05:27 PM
my monte nocks weither it is cold or warm but only after it sits for a little bit or over nite .when i changed the oil from synthetic back to regular it made the exact noise i've been hearing sounds like dry start .but only for a few seconds it sounds like it is coming from the valve train . i'm still waiting to see it if does it again .but i have noticed my car idels a little smoother. and runs cooler now that im not useing synthetic
Old 09-13-2006, 06:19 PM
I say they suck and I am not trying to sell a filter. I have used a couple in the past and both had leaking problems.
This link explains a little more
http://minimopar.knizefamily.net/oil...html#fram-tg8a
Bye Bye Blazer!
Hello Monte Carlo!
Old 09-13-2006, 11:18 PM
I finally got a decent filter for my dad's truck. Every time I service it, it had valve train noise. I switched him from Fram to AC delco, and haven't heard any noise since. His anti-drainback diaphram was bad on nearly all of them. AC may not be the best either, but sure was a step above.
Old 09-18-2006, 10:12 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
First of all I am not selling or endorsing any filter whatsoever. Fram is one of the poorest filters currently produced. I have had many examples where these filters were a result of some engine problems. I have seen many people complain about engine noise during start-up, 95% of the time the fram was used, once replaced, problem solved. I have seen engines with lower oil pressure as a result of a restricting filter. I have even taken the time to open a few frams up(tear them apart) and could easily see the cheap design, manufacturing (e.g paper filter ends inside the filter). In my opinion the WIX is very good, Purolator ( in Canada, they valvoline max life sold at Canadian Tire ) is good, the AC is also something I would use. Many (including myself up until recently) assumed that as long as the standards were met, that the filter must be good. I used fram for many years myself. There is a good write up on the net about oil filters, very good, but I can't find the link.
Old 09-18-2006, 11:45 PM
Just buy the AC Delco filter.
Bye Bye Blazer!
Hello Monte Carlo!
Old 09-19-2006, 06:35 AM
bobss396's Avatar
You know something, you are absolutely right on the Fram filter. I stand corrected regarding my previous posts.
I had changed my oil and used one recently and it does have a valve tap for more than a few seconds after it starts. I do fill the filter with oil when I installit, so its not like it had an initial dry start. Looks like I'll be stocking up on another brand!
Bob
