Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 09-12-2006, 03:04 PM
Electricblue.neon Electricblue.neon is offline
Alternator replacement
Hey
I have to change the alternator in my 98 dohc neon.Looking at where it's at,how do I get to it to change it?
Old 09-12-2006, 05:50 PM
yale329 yale329 is offline
Re: Alternator replacement
be very careful for the car should be up on ramps, and secured. Put emergancy brake on, and block wheels. It is done from under the car. Also disconnect your battery and tape the connectors good so you do not short smething out. Get a freind who knows how , and get a manuual for thirty bucks.
Good luck Wayne
Good luck Wayne
Good luck Wayne
Old 09-15-2006, 01:11 PM
Good luck Wayne
Looking from underneath there seems to be no room at all.
Someone mentioned having to drop the engine to change the alternator.Is this true or false.
Mike
Old 09-15-2006, 06:20 PM
Bear Bear is offline
You should be able to go under (disconnect battery negative cable and take off the drive belt), take off the plastic splash shield and then,above and to rear of alternator take off the mounting bolt, then remove the electrical connectors. Next move to front of alternatror near crankshaft pulley and take off the three mounting bolts and the bracket. Next hold on to alternator and take off the pivot bolt and then bring alternator out and off the car.
Old 09-15-2006, 07:42 PM
Thanks Bear
Old 09-15-2006, 09:32 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Mike
You don't have to drop the engine as you "heard". Thats just insanity to have to do that to change the alternator
Bear gave some good advice, so follow that.
2003 Dodge SRT-4
Old 09-16-2006, 12:11 AM
Dear das2123, I know, I know, and I know, wromg pesron again, and again.
Just a dad Wayne
Old 09-17-2006, 01:12 PM
Thanks Das
