Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 09-12-2006, 03:08 PM
melb0319 melb0319 is offline
Angry 78 Ford t-brid
Hey my boyfriend had sugar put in his tank to his tbird. he just got done doing the fuel line about 2 weeks ago and know this. he also just grey primored the car . we think it wnet to the engine he says it knowing but i don't hear it . is there anything we can do? also if his engine is bad does anyone know where i might find him a new engine. or a car simarl i m not trying to pay to much though.
Old 10-09-2006, 09:28 PM
melfan melfan is offline
Re: 78 Ford t-brid
The sugar in the tank is myth, but like anything, foreign objects are not good. The intake and filter sock for the fuel line is on the top of the tank so it won't do anything, besides, most tanks that old have sludge in the bottom anyway, just don't run it dry and it should be fine. I won't hurt anything. But if you want just drop the tank and drain it, have it flushed out and remount it. Not very $$. Anything that may have got into the fuel system should run itself out after driving for a while.
BTW, this was on an episode of "Mythbusters" on Discovery a few months ago, they busted it too.
As far as the engine, it depends if you want to keep it original. If it doesn't matter you can pick up a remanufactured engine for around $2,000-$3,500 or get one from a junkyard for around $500 or so. If yours has the OEM 460 they made those up into the 1980's so finding one should be easy. You can probably have a good shop rebuild the one it has now for about $3,000 but if the block is bad then you will want to get a good one.
I had the 460 in my 72 rebuild, engine compartment cleaned and repainted and everything painted to OEM stats for $3,500. This was from a high end restoration shop you should be able to get it cheaper than that.
Hope this helps,
Mark
If you can't get there in a Thunderbird, the trip ain't worth taking!
Old 01-02-2007, 03:44 AM
midgetracing28's Avatar
midgetracing28 midgetracing28 is offline
Send a message via MSN to midgetracing28 Send a message via Yahoo to midgetracing28
Re: 78 Ford t-brid
yeah its just a myth but if he is really thinking something is wrong rebuild the carb a kit is like 10 bucks. If he still isnt satisfied have a mechanic look at it so he will beleive nothing happend
