Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 09-12-2006, 10:09 AM
Biggins2121 Biggins2121 is offline
Send a message via AIM to Biggins2121
fuel pump wont come on
Ok ive got a 86 with a 2.9 now yesturday it was runnin fine. I went over to my friends and when I went to leave the thing wouldnt start. Now its getting spark and when I sprey starter fluid in the tb. it starts then dies. So I checkd the fuel pump and it wasnt coming on. So went and replaced it and it still wont start. I just dont know i pressd the little button under the dash thinking that maybe som how that might be the prob. So any thoughts thanx all KEN
Old 09-12-2006, 08:43 PM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
Re: fuel pump wont come on
Fuses, fuel pump relay, wiring problem in floorboard below seat, etc
Old 09-13-2006, 12:49 AM
smilehap smilehap is offline
did you try the fuel filter or the gas mudule
Old 09-13-2006, 09:29 AM
yeah the filter was replace a month ago
Old 09-14-2006, 07:03 AM
tundraathome tundraathome is offline
be sure to check all the ground wiring especially in tne battery area as i have had problems there sam
Old 09-14-2006, 08:38 AM
Psychopete Psychopete is offline
I can't remember if that model has 2 fuel pumps. My 88 has one in the tank and one on the frame rail, under the cab, drivers side. The intank is a low pressure pump that feeds the high pressure pump on the frame. If both are not coming on, I might look into the fuel pump relay. Trace the circuit back until you find power. For example, check before inertia switch, then move to fuel pump relay and so on. If either pump is out, the fuel system will not function properly. A fuel pressure tester would probably be helpful.
The ECC relay powers the fuel pump relay, but since the truck is capable of running, the ECC relay is probably still good. I cannot remember, I don't have the wiring right in front of me, but I am thinking power to the injectors and sensors, as well as the positive that gets switched on by the ECC relay all share the same fuse. I would need to verify this.
Run codes to verify that the computer still has it's sanity.
Pete
www.gradeight.com Pure Metal
