VATS error
i have a 95 custom with a security that like to come on..... I have my original key(Never ever had a problem with it) but i made a copy to use. its a #6. my first copy was working fonr for a month then it started to mess up. A key maker tested it and if it was wiggeled it would change resistance and say error. he said the key was bad.... i bought a new one from him, he tested it before i bought it to be sure. yesterday, my key set the security light on, so i waited for it to go off ad try agan. luckly it started on the second attempt. when i got home i grabed my original. on the way to work (the new key) set the light on again. so now i use my original. key maker suggest a bypass or a new igintion. wtf!
i have engine problems that havent been fixed, also i changed my ecm last week in hope of fixing my enjine problems. it didnt help but i didnt change it back. but why would anything effect my copied but never my original. keymaker said it coyuld of been coincidence but that is a obscene amont of coinedence. any solutins besides the bypass? better question whats the cheapest solution? |
Re: VATS error
You can also use this page as a guide: http://vats.likeabigdog.com/ Note that I suggest putting the wire in near the box behind the glove box, while the site linked suggests putting your resistor chain under the steering wheel. I think my solution is better for two reasons. One, the access is easier doing it my way. Second, the orange wires in question are very small and flimsy and could develop an open with too much fidgeting. Either way is the same thing as the two orange wires connect to the two wires I suggest you use and nowhere else. |
Re: VATS error
Not to make this more confusing or difficult. You may get lucky and save some time and efffort. You seem to be so close to the actual problem.
I would measure both keys with an Ohm meter. Also, Maybe that the bad one isnt making good connection due to its physical characteristics or dirt. Bass |
Re: VATS error
yeah... but why would this be a reoccuring problem? both key are praticly new and they send the wrong signal.
Re: VATS error
How does the connector on the theft deterrent module come out of the thing. I've gotten in to the right location but I can't get the connector loose!
I can't figure out just how to pull. There's a white clip that catches on the one side. I've lifted that and pulled but it doesn't come out easiy. |
Re: VATS error
Re: VATS error
Is the Theft deterrent module also the Body control module on a 98? |
Re: VATS error
