Old 09-12-2006, 09:10 AM
CamaroRScrazy CamaroRScrazy is offline
Driveshaft removal (sorry for the silly question)
Mine is a two-piece drive shaft. When I was trying to remove it, I took off the 4 nuts and two clamps from the rear U-joint, I took off the two nuts for the center bearing, however, the driveshaft still refused to get off from the rear end. Maybe it's because of rust, I tried to hammer it, but it is still there. Anyone who did this before?
Old 09-12-2006, 09:20 AM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Re: Driveshaft removal (sorry for the silly question)
Yeah I swapped out my old 2 piece one for the standard aluminum one. Wasn't that hard really. Sounds like you've already got all the bolts out, I couldnt imagine why it would still be hanging in there. Start beating the crap out of it. Rust could be the problem, especially if the cars been up north most of its life.
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 09-12-2006, 09:34 AM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
try some penetrating lube
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 09-12-2006, 09:37 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Bigger hammer
Nah, I'm with you on the theory that it's probably just rust. Make sure you mark the shaft position with the receiving end on the yoke and trans!
Old 09-12-2006, 09:40 AM
1986Z28's Avatar
Has a Camaro
Originally Posted by wrightz28
Bigger hammer
there an idea, btw im not talking about the bigger hammer
Old 09-12-2006, 09:47 AM
Hey guys,
Appreciate the advice. I will try them this evening and let you guys know whether they works.
BTW, for the mark of the position, all the manual requires that, does that mean the balance of the shaft can only be done after the driveshaft is installed. I'm thinking to buy an aluminum one. They claimed the new shaft is well balanced. I'm confused.
Old 09-12-2006, 11:56 AM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
if need be use a flathead screwdriver as a prybar
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 09-12-2006, 03:58 PM
1986Z28's Avatar
Has a Camaro
or you could just use a prybar as a prybar, btw john if you read this i want your shaft(check your pms) HA!
Old 09-12-2006, 04:22 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
when i helped my friend get the shaft off his 200sx it wouldn't budge with all the bolts out. we just sprayed lots of WD40, got it turning at a few rpm (it was on a lift) then got a wrench, clamped it an levered it about with the rare brakes on. took a little while but it came off quite easily after that.
Seatbelts Saved My Life
Old 09-12-2006, 06:07 PM
I used WD40, prybar, it still refuse to get off. It seems I will have to try what Straight Six suggested. You mean start the engine, get to "D" left foot on brake, right foot on gas, right?
Hope I won't damage the car.
Thanks a lot.
Old 09-12-2006, 06:13 PM
blindeyed's Avatar
eBay aDdict™
That's weird that it wont budge at all. When I removed the center supports off mine (where the velocity joint is) the middle sagged down and all I had to do was move that section up and down and it just dropped right out. Are you sure you have all the screws out that hold up the center section? It really shouldnt be that hard, especially with a 2 piece shaft.
- Jason
Old 09-12-2006, 06:23 PM
Thanks a lot.
make sure the driven wheels are off the ground. what we did was put the accelerator in really gently, so the wheels are turning really slowly, the rolling resistance in the hubs and diff may just be enough to loosen it. we never had the shaft moving at more than a few rpm because we didn't want the u-joints to suddenly disengage and have the driveshaft suddenly drop and hit something.
if it still wont budge you could try putting the handbrake on (as little as possible, don't make it so the wheels are 100% locked solid) and giving it some gas (again, only a few rpm) that may work, but don't hold me responsibe if something goes wrong.
Old 09-12-2006, 06:57 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Sometimes the joint caps stick in the yoke. Like almost the point to being pressed in. You don't want to be hammer in there though. I am sure your pinion bearings don't care for the jarring. You want to apply continuous solid pressure. Take a pry bar preferable and just keep apply more and more pressure. As long as all the bolts are out, it will pop off. Good luck
Edit- Also the penetrating oil/wd40 will help loosen it up as well. Try adding a little of that as well.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 09-12-2006, 09:28 PM
balls_to_the_wall's Avatar
balls_to_the_wall balls_to_the_wall is offline
If all else fails you might be able to heat it a little wiht the oxygen wrench...
*Don't hold me responsible if you screw something up..*
Old 09-13-2006, 12:15 AM
WHOA wait time out
you Do realize it needs to be pushed into the tranny a little bit first right?
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
