Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-11-2006, 09:04 PM
asapwarranties asapwarranties is offline
STALLING eclipse 2.0 the answer
hello everyone if you are wondering why your 2.0 non turbo eclipse is stalling while driving then you problem is the speed sensor located on top of transmission below battery. i listened to everyone and they said one thing after another i replaced the cam and crank sensors, temp sensor,fuel pump relay,computer,battery,alternator,tps,fuel pump,filter and it is the speed sensor that causes the stalling while driving and allows the car to start again.
Old 09-11-2006, 10:22 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: STALLING eclipse 2.0 the answer
uhhhmmm....
Not everyone is going to have the exact same problem as you, but the symptoms you describe could have been many things. Glad you figured it out though...
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 09-12-2006, 09:48 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
...... when my rod bearing was beginning to spin it would die after going WOT and start right back up again.......
Boost leak maybe?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
