Go Back   Automotive Forums Car Chat > Buick > Regal
Old 09-11-2006, 05:29 PM
PRL2931 PRL2931 is offline
Valve Rattle:
1989 Buick Regal
2.8 MPFI V6
70,000mi
Engine Oil light flashes sporadically. No smoke, no leaks, no smell. Intermittent knocking sound coming from valve cover.
Sounds like I need a valve adjustment. What do repair shops usually charge for this?
~L
Old 09-12-2006, 06:43 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Valve Rattle:
Welcome to AF!!
Actually there is no adjustment on the valves of this particular engine. I think your issue is directly related to the oil light coming on. Low oil pressure will cause the noise you hear and it probably is due to oil starvation. I would check about an oil pump replacement before dealing with the valve issue as I think that will solve the problem. Oil pump replacement $300 to $600 depending on the shop and labor rate.
