Go Back   Automotive Forums Car Chat > Cadillac > Eldorado
Old 09-11-2006, 02:34 PM
eldorado98 eldorado98 is offline
Eldorado 98 intermitting start problem
I am having a problem with my 98 Eldorado, Northstar, 88,000 miles. When I start the car in the morning, it starts easy. If I restart it within 20 mins it starts easy. If I try restarting it after 1/2 hour, even after 3 hours it cranks and cranks and finally starts. What could be the problem?
Old 11-25-2006, 12:05 AM
MasterMind1 MasterMind1 is offline
Re: Eldorado 98 intermitting start problem
after running it for awhile, pull the vacuum line off of the fuel pressure regulator, check for fuel coming out of the regulator through the vacuum conection port
Old 01-10-2011, 12:36 AM
rzacc's Avatar
rzacc rzacc is offline
Greetings. I am wondering what the outcome was to this problem. My mother bought one and it is doing the same thing. However, her car will start if she turns the key off, then restarts. When it is warm, it will often not start on the first try, but just crank. It almost invariable starts on the second try.
Thanks in advance.
Old 01-10-2011, 10:21 AM
caddydaddy caddydaddy is offline
Thanks in advance.
I'd have the engine codes checked. It sounds to me like the crankshaft position sensors may be bad. It's a fairly common starting problem. But you need to have the codes checked to confirm.
2000 Cadillac STS
2005 Cadillac Escalade
2008 Triumph Sprint ST 1050 ABS
Old 01-10-2011, 10:44 AM
Scrapper Scrapper is offline
AF Premium User
can you get it to a auto zone you can get it scaned for free of course. may be fuel pump or coil.
Old 01-23-2011, 08:51 PM
rzacc's Avatar
Thanks Gents. I'll pass it on to her.
