Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 09-11-2006, 12:48 PM
scott_thomp79 scott_thomp79 is offline
Injectors
I have a cracked stock injector tip and now i am looking for all 4.I have a manual 95 neon with a cold air intake,and 10.5mm spark plug wires.Im looking for info on injectors to use on a non-turbo setup.THXS
Old 09-11-2006, 05:28 PM
the_game_rock's Avatar
the_game_rock the_game_rock is offline
Re: Injectors
I have some ill sell you for cheap. Stock ones.
Old 09-11-2006, 10:25 PM
Re: Injectors
I am want to slowly upgrade whole the car,srry i want to stay away from stock.I was thinking venoms but I dont know the flow rates.I want to upgrade to a auto T/B than maybe bore it out.I would like to upgrade the injector to what I will NEED....THXS though.....Any ideas guys?
Old 09-11-2006, 11:22 PM
Re: Injectors
What are you planning on doing?
Old 09-12-2006, 02:39 AM
Re: Injectors
Im kinda stapped for cash so Im working on the slowly but surely.In the future a turbo and a new fuel system would be nice. Also I read that installing a DOHC stock comp into SOHC neon is better than reprogramming your SOHC comp.http://www.sportcompactcarweb.com/pr...e_neon_part_2/.
I dont know the more I read and learn the more I want to do. But its hard on a low buget.plus Im tuning my 05 crf450x so its hard to say whats more important.
Old 09-12-2006, 10:27 AM
neon_rt's Avatar
neon_rt neon_rt is offline
Re: Injectors
The air flow curve of the Sohc and Dohc are enough different that you will not see hardly any (if any at all) increase of power by putting a stock Dohc computer on a Sohc. You would be better off saving your money and putting the correct computer on your Sohc. The article used a MP Dohc computer, which is the same price as the MP Sohc computer. They chose the Dohc computer b/c they had intention on adding mods to the Sohc to increase it's high RPM power (above 6500 rpm) in the future. Unless you are really serious about having a hotter cam/new intake (Indy) and port matched Magnum head, you will be better off with a Sohc Mopar Performance or AF/X computer.
The thing is: You have a '95, There are some weirds things about the '95 that was changed in '96. One of them is the fuel rail and Injector connectors are not compatible with most aftermarket injectors. Many people have changed out their '95 computer/harness/injectors and rail for a '96-'99 before they started doing any other mods.
