Old 09-11-2006, 09:45 AM
KustomizedKreation KustomizedKreation is offline
03 Cavy Steering Wheel Removal
Hey Guys,
I need to know how to remove a factory steering wheel from a 2003 cavalier to install an aftermarket steering wheel..I was wondering if anyone knew how to do this. im worried about the air bag going off..does anyone know how to disable the air bag and remove the stock steering wheel? please let me know..thanks
Old 09-11-2006, 01:58 PM
Lances133's Avatar
Lances133 Lances133 is offline
Send a message via AIM to Lances133
Re: 03 Cavy Steering Wheel Removal
Pull the airbag fuse on the side of your dash, or if you're THAT worried, disconnect the negative battery connection as well. I wouldnt know about 03+ but I'm pretty sure it should be the same....on my 98 there are 2 7mm bolts behind the wheel that release the airbag, then there is one large nut in the center of that, that holds the wheel onto the column.
Old 09-11-2006, 02:09 PM
Smile Re: 03 Cavy Steering Wheel Removal
awesome thanks,
do you know if it will cause teh check engine light to kick? and if so how to turn that off? also will I need any special hubs or anything like that..other than of course a standard hub which comes with a new aftermarket steering wheel? I heard somewhere you have to have an adapter of some sort..does anyone know anything about this?
Old 09-11-2006, 03:12 PM
Lances133's Avatar
If the airbag fuse is out, then the Airbag light will come on. I believe if you put the fuse back in then the passenger bag will still function and the light will go off, someone correct me if im wrong.
But yes, you're gonna need the Momo hub adaptor. It took me awhile to realize this myself, it will look like this...
...that is what the hub and aftermarket wheel sits on.
The momo adaptor is gonna run ya from $60 if you're lucky to about $80, there is this one on eBay however that is going for about $70 AND it comes with a wheel, so ya mine as well get this one here and get a free/spare wheel
http://cgi.ebay.com/ebaymotors/82-02...spagenameZWDVW
Old 09-11-2006, 03:23 PM
Thanks I really appreciate it..
Old 09-11-2006, 03:27 PM
Lances133's Avatar
No problem dude.
