Go Back   Automotive Forums Car Chat > Ford > Mustang > Non-Performance
Non-Performance This is the place for all interior, exterior, and general non-performance modifcations.
Old 09-11-2006, 09:02 AM
jmbuds jmbuds is offline
Rear window install problem
I've got a 67 mustang coupe. The rear window has been removed. I can't get the new window and gasket back in. I'm afraid I will break the glass if I push any harder. Someone is inside pulling the string fitted inside the gasket. Any suggestions? Thanks.
Old 09-11-2006, 05:08 PM
motorjock205's Avatar
motorjock205 motorjock205 is offline
Send a message via MSN to motorjock205
Re: Rear window install problem
Might try spraying the gasket liberally with WD 40 to see if that would help.
Forget World Peace, Visualize Using Your Turn Signals!!!
Carl W. Ervin
2008 Shelby GT CSM 08SGT0235
Old 03-01-2007, 10:58 PM
smurfmobile smurfmobile is offline
soapy water works too, also check a criss-cross measurement to make sure the car doesn't have a bad repair. (replaced roof, or one of the sides)even check top to bottem, top sice to side, bottem side to side, also glass measurements,
