HELLO
I have fluid to the brake but it must be plugged up in the drum because it doesnt come out the bleed valve. How do I get the darn drum off!!! Has anyon ehad this problem. all the other brakes have been blead out and the brakes work if you pump them . I tried blowing commpressed air from the beeder to the line having removed both line and bleed valve with no result. I need to take the durm apart and check it out but I cant get it off.. HELP PLEASE! Don |
Re: 1985 bmw 318i rear brake PROBLEM!!!
have you lossened the adjuster on the inside of the drums?
thanks for the tip its been awhile and I forgot about the adjuster
Did that work? |
No I couldnt get the adjuster to loosen I did get the thing off eventually but bent the adjuster in the process it was easy to bend right back in place and after cleaning up the piston and other parts the brakes bleed good and they work fine.
IS THERE SOME TRICK TO LOOSENING THE ADJUSTER??? |
well as long as you cleaned it up wel land put some lubricant on it that is the best that you can really do. good luck.
