Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 09-10-2006, 07:32 PM
ysteve ysteve is offline
Help P0440
Hi guys, i keep having this p0440. I change the gas cap but it still coming back every 3-4 days. I check vacuum lines but never find a leak. Maybe there is some spots wich you gonna recomend to check? Or its not because of leak? Any questions go to "No cat".
Thank you
Old 09-11-2006, 04:02 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Help P0440
With a P0440 OBD-II trouble code, diagnosis can be tricky at times. Here are some things to try:
Remove and reinstall the gas cap, clear the code, and drive for a day and see if the codes come back.
Inspect the EVAP system for cuts/holes in tubes/hoses
Inspect for damaged or disconnected hoses around the Evap purge solenoid
Check and/or replace the sensor
Check and/or replace the purge valve
Have a professional use a smoke machine to detect leaks
Since you've tried many of the tests, I think a professional smoke machine test is your next step.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 09-12-2006, 10:29 PM
BostonKev BostonKev is offline
Re: Help P0440
is the sensor located up under the drivers rear fender or on closer to the tank?
Old 09-13-2006, 08:03 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Help P0440
The sensor (pressure) used to monitor vacuum decay in the evaporative emissions system is located at the top of the fuel pump assembly located right on top of the gas tank.
The P0440 DTC indicates it is a large or gross leak.
Sorry ysteve it took a while for me to get to your PM.
Timeslip 08/12/06
AF Community Guidelines
Old 09-13-2006, 10:30 AM
Re: Help P0440
thank you for the info.
Not to butt in on the thread but I had the same code and after I would reset it it would come on roughly a day later. I removed and inspected all the all the rubber hoses going to the canister up under the rear quarter also on the hose that heads to the top of the tank. I placed a little bit of silicon on the end of the hoses thinking it would help make it air tight and it only comes on every week or so now which makes me believe the actual issue might be the canister itself. Does that make any sense? BTW, the gas cap has already been replaced.
Old 09-13-2006, 10:51 AM
BNaylor's Avatar
Re: Help P0440
I would recommend checking the vacuum lines from the charcoal cannister to the purge solenoid located engine side. It looks like you have the other bases covered. According to the GM service manual a faulty or damaged charcoal cannister can trigger a P0440, therefore it makes sense to me. That applies to a 3800 or 3400 equipped Impala.
Timeslip 08/12/06
Old 09-13-2006, 09:50 PM
Re: Help P0440
can I trouble you to tell me where I can find the purge solenoid? It's a pain to track these things w/o a lift. Thank you
Old 09-13-2006, 10:00 PM
BNaylor's Avatar
Re: Help P0440
Which engine do you have?
Timeslip 08/12/06
Old 09-13-2006, 10:02 PM
Re: Help P0440
3.8 police
Old 09-13-2006, 10:25 PM
BNaylor's Avatar
Re: Help P0440
3.8 police
Passenger (right) side of engine in front of the UIM/plenum. Circled in red in the pic.
Timeslip 08/12/06
Old 09-13-2006, 10:42 PM
Re: Help P0440
thank you
Old 11-10-2006, 04:24 PM
LeapFrog777 LeapFrog777 is offline
Re: Help P0440
I'm curious did this p0440 problem ever get resolved? If so how was the correction made. Thanks.
Old 11-11-2006, 08:02 PM
ogre73 ogre73 is offline
Re: Help P0440
I'm curious, where would the solenoid be on the 3.4L? I have had this code for over a year now, and have another inspection coming due soon. I would rather fix it then try to trick the inspectors again.
Old 11-12-2006, 08:08 AM
BNaylor's Avatar
Re: Help P0440
If you are referring to the purge solenoid, it is located to the right of the throttle body bewteen the IAC and EGR valve. See pic below.
Timeslip 08/12/06
Old 11-12-2006, 08:25 AM
Re: Help P0440
Thanks! I will check it and see if that gets rid of my problem. Haynes isn't descriptive enough to tell me where it was, so again, thank you.
