Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 09-10-2006, 03:42 PM
dblhelix dblhelix is offline
P0171 Code-- can someone help?
I am receiving the code P0171 (fuel system for bank 1 is too lean)
--any suggestions as to what this means or what fix is required?? Is it simply the o2 sensor??
I have already replaced the downstream o2 sensor. I am not the most experienced with this sort of thing-- I can replace a sensor or two-- but that's about it...
Any help would be appreciated!!
01 Jetta GLS; 60,000 miles (2.0)
Old 09-24-2006, 10:28 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Re: P0171 Code-- can someone help?
check for vacuum leaks (fuel pressure regulator vacuum hose on belt side of engine under engine cover)
if there are no leaks replace the maf sensor
