Old 08-28-2002, 09:41 PM
djmr2's Avatar
djmr2 djmr2 is offline
Making Paint Booth!!
Hey guys
so i decided i'm gonna make a paint booth because i bought airbrush..
now.. i just got some plywood and made a box, but now i'm having a hard time deciding where to mount the fan.
I bought a 120MM Sunon Computer fan which says it moves 90CFM, probably enough for what i need it for ..
Should i mount it closer to the opening in the front so it'll suck up all the fumes before they escape into the room, or mount it towards the back so when i spray, the over spray will go towards the fan....
the problem i see with the fan being mounted closer to the opening is that it won't get some of the overspray cuz it'll probably give it a chance to settle... and if i don't put it closer to the front it might let fumes out??
any thoughts??
Old 08-29-2002, 11:31 AM
lotus_man's Avatar
lotus_man lotus_man is offline
Unhappy
Take great care with this projec! A build up of paint fumes can be highly explosive.
I remember Scale Automodeler did an article on building a spray booth a few years back and they reconed it was best to get a fan designed for the job. The problem was the sparks from the motor of a regular electric fan could cause the fumes to explode...
Let me know how you get on, I've just moved house and now have my own modelling room, so I'm planning on building a booth when I have the time (and I'm not building cars!).
Old 08-29-2002, 11:47 AM
jaykit21's Avatar
jaykit21 jaykit21 is offline
Banned
Very good point by lotus-man. It would suck not having eyebrows for a few months!
Here are some spray booths from Paasche.
http://www.paascheairbrush.com/main.html
(look at the bottom right...)
It looks like the rear or top 3/4 fan mount would work the best.:bandit:
Old 08-29-2002, 11:48 AM
freakray freakray is offline
AF Modelrater
If you put the fan at the back of the booth, it will draw the air back into the booth and this will prevent the fumes coming forward.....this will also help draw the over-spray away .......what are you doing about a light source?
I cut a window in the roof of my booth, put a piece of lexan over the opening and have a fluorescant light above....it works pretty good.....
make sure to duct the fan to the outside so the fumes aren't just getting moved too....most computer/panel fans are brushless anyhow, so there should be little to worry about when it comes to sparks....
Ray
AF User Guidelines
Old 08-29-2002, 12:32 PM
djmr2's Avatar
yeh i got a brushless fan i rather enjoy my eyebrows!
for lighting i'm gonna try some mounted lamps outside of the booth first.. if that's no good i'm gonna get some clear lucite or lexan or whatever and get a flourescent tube..
looks like i don't really have anywhere to put my paint booth right now..
i'm gonna try sticking it under the range hood and having that suck the crap outside..
hope that works good..
Old 08-29-2002, 12:41 PM
flyonthewall's Avatar
Car Mod guy
For my booth i fitted a bathroom extractor fan which is not very good at all. I want to fit a better one and thought a computer fan may do the job, but i want to know how a computer fan will hook up the mains??? They normally plug into a motherboard, don't they?
Old 08-29-2002, 01:32 PM
AF Modelrater
Chris,
Not all do....I have an industrial type panel one, I say that because I have only seen them used in the large control panels used in a factory or the like. Anyways, mine actually runs off mains power, which is the usual 110V here in the USA, but you may be able to get something similar.....I am not sure where though, I got mine at RadioShack, but I guess you could try any computer/ electrical wholesale place.
Hope this helps....
Ray
AF User Guidelines
Old 08-29-2002, 03:22 PM
Car Mod guy
Thanks Ray, I'll look into it.
Old 08-29-2002, 03:49 PM
daggerlee's Avatar
I just simply use the range hood in my kitchen. I erect a detachable cardboard box around it. I'm not too worried about exploding paint fumes, I have never EVER heard of a paint booth exploding. I remember somebody did a study and found the air/paint mixture was far too lean to cause an explosion.
Dan
Old 08-29-2002, 05:05 PM
djmr2's Avatar
probably not a explosion but a nice fireball might happen..
the amount of air vs the amount of flamable gases that we are spraying is very high in air.. i mean air is everywhere
Old 08-29-2002, 06:20 PM
modelfan1's Avatar
modelfan1 modelfan1 is offline
Send a message via AIM to modelfan1 Send a message via Yahoo to modelfan1
I read on another forum about a member that had an explosion of the fumes in his booth, the story was related to the forum after a lengthy stay in the hospital for severe burns to the face and upper body !!
:bandit: Mike
Old age and treachery will overcome youthful exuberance everytime !!
Old 08-29-2002, 09:21 PM
djmr2's Avatar
:bandit: Mike
hmm interesting..
so how abouts did this happen... what kind of fan was he using?
Old 08-29-2002, 09:29 PM
Ranger_X's Avatar
Ranger_X Ranger_X is offline
does anyone know how to make one without atmosphere venting? I live in an appartment so I can't exactly vent outside. Someone linked a site a while ago.
-Will-
96 M56 Volvo 855 Turbo
87 A555 Chrysler Daytona Shelby Z
Old 08-30-2002, 07:56 AM
modelfan1's Avatar
[hmm interesting..
so how abouts did this happen... what kind of fan was he using?]
One that had brushes and was not shielded!
I use a Hepa rated air cleaner that removes 99.9 % of all particulate
matter from the air as well as fumes like lacquer and cigarette smoke.
It's connected to the spray booth by a dryer hose.
:bandit: Mike
Old 08-30-2002, 08:18 AM
ales's Avatar
ales ales is offline
Forza Schumacher
:bandit: Santa
Pics?
:bandit: Alex
Your Current Paint Booth: Likes/Dislikes fochsml Auto Collision Network 1 10-21-2011 10:38 AM
Paint booth ideas dag65 Car Modeling 6 07-28-2003 05:52 PM
homemade paint booth!! BLAH! djmr2 Car Modeling 16 11-07-2002 09:08 PM
Paint Booth?!?!? fullbloodchop01 Car Modeling 1 08-23-2002 08:17 PM
spray paint booth lamx Car Modeling 3 08-16-2002 07:56 PM
