Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-10-2006, 01:38 PM
shelnick shelnick is offline
95 eclipse wont start wont run
95 eclipse wont start / run
at my wits end - any advice is appreciated - I have a 95 eclipse 2.0 non turbo GS -
Driving normally, the car quits running. seemed like it ran out of gas. I have no spark, no psi in the fuel rail. I have changed the PCM, cam sensor, crank sensor, coil, plugs, asd relay, fuel pump relay and checked the fuel pump, it works fine. I get codes 11, 36 and 12 in the pcm. 11, no crank signal. With the key on, I have 8 volts of supply at both the cam and crank sensors, 5 volts of signal at both sensors, and the grounds check out. Still no spark.
any advice?
Thanks
Old 09-10-2006, 02:49 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: 95 eclipse wont start wont run
Originally Posted by clipse_thumper
messed up again. you posted the same question in 2 places? not cool. they will move your last question to the correct sub-forum since you didn't know.
Dude just chill out, you told him to move it and he did, it's more your mistake. Next time tell them to post in the correct sub-forum NEXT time they post.
Are those the self-diagnosis codes or the codes read through the OBDII system?
95 Talon TSI AWD
97 Eclipse GST
Old 09-10-2006, 05:59 PM
First off, sorry about the confusion on the posting stuff. Not familiar with your catagories, sub catagories, as this is my first crack at your forum. All I am looking for is to connect with someone competent on DSM problems to help me solve this one. I know a lot about these cars, I will be glad to share what I know in this forum as well.
As for the codes, they are flash counts from the check engine light after on- off - on - off - on.
Thanks for the reply, I appreciate the help.
