Old 09-10-2006, 01:15 PM
lrall lrall is offline
Exclamation Trans fluid service
Well first off im not doing a flush, i just want to drop the pan do the service that way. My understanding is that after you have your car all jackd up and on stands you can start unbolting the tranny pan(with something to catch the fluid underneath) and let the fluid drain. Here comes the frist question, i assume when unbolting the pan fluid will start to leak out, do you take it slow and let all the fluid drain out or....Then once all the fluid is out, replace filter(idk what this involves ive never been inside my tranny ) then bolt the pan back up, pour fluid in thru the dipstick hole and check it, then start the car, and check/add as needed, and also, how do i make sure i dont over fill it? Im half paranoid about doin it, any comments, directions, ANYTHING on this is greatly appreciated
LR
Old 09-10-2006, 06:47 PM
Willyum Willyum is offline
Re: Trans fluid service
You have the right idea. Is a procedure to unbolt so it starts draining out of one corner but I've never mastered that, it's a real mess but you can somewhat control it. Originates from the fact that the fluid level is above the pan seam. Be sure to clean out the pan and magnetic washer. I have an '02 Vulcan and drain out w/refill took 7 qts. (be sure to refill with Mercon V) I recommend letting it down level before you start filliing because the dipstick/filler tube won't take it very fast and too fast will result in new and expensive fluid on the ground/floor.
Old 09-10-2006, 08:09 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
LR
Your 94 taurus takes dexron 111 transmission fluid.
If the transmission pan has the thick stiff type rubber resuable gasket
reuse it.
Add about 3 1/2 qts and start checking with dipstick engine running.
On the final level check get it good and hot after 10-15 minute drive and recheck fluid level.
If way overfull drain some out down to correct level.
MT
MT
Old 09-10-2006, 08:51 PM
whoops, sorry my profile was wrong its a 2002 taurus, i use mercon 5 i think, i guess we'll see how it goes since ill be doing it this week, gonna go buy about 9 qts of ATF just to make sure i have enough
Old 09-11-2006, 08:52 AM
MT-2500's Avatar
AF - Advisor
OK 2002 needs Mercon V
But also on them they need a total flush with the filter change.
You need to get all of the old fluid out of it or it will ruin the new fluid.
One of the ford deals.
MT
MT
Old 09-11-2006, 02:11 PM
Millermagic Millermagic is offline
I would reccomend changing the filter along with cleaning the magnet while you're in there.
- Leather - Transmission Cooler - Gen III Tweeter Sails - Gen III Rocker Covers -
As you walk through the valley of RICE, you shall fear NO V-TEC, for torque is with thee!
Old 09-11-2006, 04:11 PM
another question, where EXACTLY are the correct lift points? i know there are spots that will work but....
Old 09-11-2006, 05:11 PM
MT-2500's Avatar
AF - Advisor
The owners manual should head you in the right direction.
https://www.fleet.ford.com/maintenan...ls/default.asp
MT
MT
Old 09-11-2006, 06:23 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Found my site didn't ya sherlock??
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 09-11-2006, 09:31 PM
im lost??
Old 09-12-2006, 09:58 AM
MT-2500's Avatar
AF - Advisor
10-4 Way2old
Good site and it is free.
Sherlock/Crunch/MT
MT
Old 09-12-2006, 10:24 AM
way2old's Avatar
TOKEN HILLBILLY
Irall--- My post was for MT-2500. We have known each other a while and I had to give a little jab. Sorry if it confused you. The site he gave you has a lot of free information for Ford owners. You can also go here and search a lot of info on your vehicle. Again, I apologize for the confusion.
Old 09-12-2006, 06:11 PM
oh, cool cool, yea i knew about ford.com...lol, the other i did not, but thanks for the tip, thanks for the help everyone, sounds like ill be doing a fuel filter soon also...since thats due..oh A LONG TIME AGO, silly parents think maintenance is just oil changes....ahh well i enjoy it, again, thanks
Old 09-12-2006, 07:40 PM
james2k james2k is offline
MT
I'm looking to have trans service done on my 03 taurus this week, and am still not sure which route to take. I really think I should drop the pan, change the filter and gasket, then refill with Mercon V. Is it really necessary to flush the trans? Thanks!
Old 09-13-2006, 05:45 AM
mwt878991 mwt878991 is offline
If you want to change half of your fluid a pan drop will work.
If you want to change all the old fluid I would suggest following this procedure.
I have done it several times on the three Taurus setting in my driveway.
http://www.taurusclub.com/wiki/index...ission_at_home
Mike
