Old 09-10-2006, 10:01 AM
mountie1982's Avatar
mountie1982 mountie1982 is offline
Evaporative System Monitor????
I had some problems with my blazer. I seemed to have fixed them by replacing the o2 sensors. I have an obd2 reader and by using this as a guide I have managed to almost fix it. My problem now is that now when I scan the comp it shows no codes (the good news) BUT it shows the the Evaporative System Monitor icon flashes and the yellow light on the reader goes off. What does this mean???
2006 Dodge Ram 1500 Quad
Why Dodge it when you can RAM IT?
1964 Vw Baja 1600
Old 09-11-2006, 11:48 PM
mdrush mdrush is offline
Re: Evaporative System Monitor????
It may mean the EVAP tests from mode 6 haven't run. It takes some specific conditions to run...ie fuel level, fuel temp, fuel tank pressure etc. The test flag is reset every time you reset the MIL.
On my scanner any non-continous test that haven't run yet will be highlighted in yellow to alert you that the vehicle is not ready for emissions testing.
Old 09-11-2006, 11:56 PM
Found the minium test entry conditions (may vary with year)
MinimumMaximumEngine off (soak) time 6 hours
Time since engine start-up for 0.040”330 sec1800 sec
Time since engine start-up for 0.020”idle test30 sec600 sec
Refueling event (for 0.020”idle test only) - none
Intake Air Temp for 0.040”40oF 90 -100 oF
Intake Air Temp for 0.020”40oF 90 oF
Vehicle Speed for cruise test, 0.040 and 0.020” 40 mph - 80 mph
Vehicle Speed for idle test, 0.020” 0 - 3 mph
Fuel Fill Level for 0.040” 15%-85%
Fuel Fill Level for 0.020” 40%-85%
BARO (<8,000 ft altitude) 22.0 “Hg
Engine Load 20%-70%
Purge Dutycycle75%-100%
Fuel Tank Pressure Range-17 H2O1.5 H2O
Old 09-12-2006, 11:05 AM
Well its seem to have been fixed. I was reading the thread about reseting the computer. I relised I did all the steps but one thing and that was to let it idle for a few minutes. I let it idle under load for 5 min and then drove it. WOW it ran so smooth. Re scanned it and GREEN light and no error codes. YAY I like my blazer again. LOL I drov eit for about 150km now and still all good. Thanks for you input anyways.
1964 Vw Baja 1600
