Old 09-10-2006, 09:52 AM
CamaroRScrazy CamaroRScrazy is offline
Vibration problem
96 Camaro RS V6 3.8L 110 K.
When I'm driving above 50 MPH, I can feel vibration from the front end of the car.
Does that mean it's the problem of the front suspension or steering? Can we eliminate the chance of a driveshaft problem? A lot of people are talking about aluminum driveshaft.
Thank you!
Old 09-10-2006, 11:07 AM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Re: Vibration problem
Rotated and balanced your tires yet? Sounds like the problem to me.
Old 09-10-2006, 11:56 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Definitely sounds like a tire issue. It could be more than just a balance, however. It could mean a tire is separating, which could lead to tragic results. I'd get it looked at if I were you (RS crazy). Take it to a Discount Tire, they'll check it for free.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 09-11-2006, 08:15 PM
Silicon212,
Thanks for your reply!
Separating? Sounds horrible. But I just have my tires changed. I got two new tires for the front wheel and rotated them to the rear, then I did a balance for all of the 4 wheels.
Old 09-12-2006, 08:56 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Shop may have overtightened the lugs and warped the rotors.
OR, the weights used for balancing weren't on right and fell off.
OR, the lugs are loose and you susequently have a loose wheel
Check your lugs, and take it back. Especially since they put 2 tires new on the front where the problem exists.
