Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 09-10-2006, 09:42 AM
djtroz djtroz is offline
2001 Expedition, Spark Plug 1
I just bought the car around a month ago, and last week I noticed when trying to accelerate, the car lags and has some trouble. I brought it to Autozone and they are telling me plug 1 is misfiring. I looked around the engine and couldnt easily locate the plugs. Can someone direct me to where they are and also the firing order?
Old 09-10-2006, 12:40 PM
Re: 2001 Expedition, Spark Plug 1
Ok, I located the plugs. This is the first vehicle I've owned that has individual coil packs and I was looking for normal plug wires. If anyone can provide the firing order, or which is plug 1, it would be appreciated.
Old 09-10-2006, 01:24 PM
KimMG KimMG is offline
AF - Advisor
Which motor?
Old 09-10-2006, 02:54 PM
4.6 Sohc
Old 09-12-2006, 09:33 PM
makanamail makanamail is offline
It is always the one on the passenger side and most forward from the passenger compartment on the Ford engines.
Old 09-13-2006, 11:38 AM
Expo172 Expo172 is offline
Send a message via AIM to Expo172
I am just logging in because I have the same problem. I was told by a tune up place that it would cost over $400 to have a tune up. I want to try it myself any suggestions and how did it go for you. Please.
Old 09-14-2006, 07:54 AM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
I would not suggest you change the plugs yourself. The the coils themselves are about $60. And the spark plug on the rear passenger side is really hard to get to. But the coils down really need replacing, my 2000 Expo has only had one replaced and his 150k miles. Anyway good luck.
Old 09-14-2006, 10:02 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Usually the coil does not fail (most of the time). The spark plug boot will allow the spark to go through it and cause the misfire. Replacment of the boots along with the plugs should cure the problem. Replace the entire coil as a last resort to cure the miss.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 09-15-2006, 06:54 AM
Well, I bought a new set of plugs and one coil pack. The guy at Autozone said the coil packs rarely fail, it was in the '97 models that had most of the problem. He said to try the plug and that sure cure it, which it did. It took a day for the check engine light to go off and the truck seems to be running better. I need to change the other 7 plugs, which appears to be a chore being half of them are buried in the back on the engine.
Old 10-11-2006, 08:36 PM
rhandwor rhandwor is offline
Make sure you buy double platinum plugs as they are hard to change especially on the 5.4L.
