Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 09-10-2006, 09:24 AM
moif moif is offline
tail lights
I have tail lights inop. on my `87 caprice classic and I can`t find any way to access the bulbs to change them. Tried gaining access through the trunk and under the rear bumper but no luck. Can someone tell me how to get to those bulbs.
Thanks.
moif
Old 09-10-2006, 11:40 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: tail lights
Thanks.
moif
When you open the trunk, you will see three Phillips-head screws in the fiberglass back section aiming down into where the taillights are. There are three per side (and two in the middle). The two in the middle give you access to the license plate light, and the three on each side - well you remove those and the top of each taillight assembly will lean out. Simply rotate the tops downward and pull the assemblies upward to remove them and gain access to the light bulbs.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 09-10-2006, 05:39 PM
Re: tail lights
Done! Don`t know how I missed those 3 screws.
THANKS.
moif
