Go Back   Automotive Forums Car Chat > Land Rover > Mechanical > Hydraulics
Hydraulics Clutch and brakes.
Old 09-10-2006, 04:13 AM
If it aint broke If it aint broke is offline
Disco clutch hydraulics
Hi there,
My trusty old Disco has started to play up. The clutch hydraulics have bit the dust. I've changed the master and slave cylinders, bled the system, but the pedal is "slack" until approx an inch from the floor. It refuses to go any further. Checked out the usual failures (push-rod through release arm) but this appeared to be OK. Any suggestions?
Old 09-22-2006, 02:43 AM
KiwiBacon KiwiBacon is offline
Re: Disco clutch hydraulics
Originally Posted by If it aint broke
Hi there,
Is the clutch fork moving?
I had a similar issue once, the clutch fork had worn thin, was cracked and flexing rather than moving the release bearing.
Old 09-23-2006, 06:16 AM
Fixed it now - release fork was broken - cost wasn't too bad but a nightmare of a job!!
