Old 09-09-2006, 10:47 PM
persuazion persuazion is offline
Will washers mess my battery up?
On my 99 lesabre battery the negative cable hole has been stripped and the screw connecting the cables will only tighten if I put 3 or 4 washers inbetween.Will this mess up my battery or cause any electrical problems with my car? The battery is fairly new and Id hate to have to replace it becuase of that.Thanks for any advice..
Old 09-10-2006, 04:53 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Question Re: Will washers mess my battery up?
I am not sure that I understand how adding washers would help overcome “stripped” threads in the battery. If you add washers, you are in effect reducing the number of threads available to secure the terminal. This seems bassackwards! Are you sure that the terminal bolt is not too long & therefore bottoms out in the female threads before tightening the terminals?
Old 09-10-2006, 07:28 AM
Velocity59 Velocity59 is offline
Also you need to be aware that the bolt does'nt bottom out too far or you will be in danger of going through the battery causing an acid leak. You say the battery is fairly new? does it still have a warranty?
Old 09-10-2006, 09:58 AM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Also, washers will not hurt your battery nor will they hinder battery output.
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
