Old 09-09-2006, 10:26 PM
thoughtpolice thoughtpolice is offline
350 Upgrades
Hello. Im in the process of buying some parts for a chevy 350 tbi. I had some questions before I buy a cam kit. I was told my engine "...probably has a flat tappet even though it was designed for a roller..." sooooooo I was wondering what I should order.........
Do I need a retro-fit kit or does that mean that I can order just a regular replacement kit for a little cheaper?
Also what is the difference between a hydraulic flat tappet and a hydaulic roller tappet?
If I go to a hydraulic roller do I need to get a roller timing chain?
Please help! Thank.s
Old 09-10-2006, 08:20 AM
maxwedge maxwedge is offline
A990 racer
Question Re: 350 Upgrades
And the year of the engine is?
Old 09-10-2006, 03:02 PM
Re: 350 Upgrades
It is on a 89 2500. However I think it has a aftermarket crate motor. I just bought the truck a few weeks ago so im not sure if it was rebuilt or what....Where can i look on the motor for helpful serial numbers?
Old 09-10-2006, 03:10 PM
A990 racer
Re: 350 Upgrades
To id the the block check this link. http://www.nastyz28.com/sbchevy/sblock.html BTW, a 89 engine did not have a roller cam , a true roller timing chain and gears has nothing to do with whether the cam is a roller type or not, just aftermarket h/d part.
Old 09-10-2006, 04:28 PM
fuzzypuppy's Avatar
fuzzypuppy fuzzypuppy is offline
Re: 350 Upgrades
I see from your profile that your truck is an 89, if the engine is original then more than likely yes your engine is a flat tappet with provisions for a roller valvetrain.
The major difference between the two is in the lifter, the bottom of the flat tappet lifter has a flat surface that rides on the lobe of the cam, thus the term "flat tappet".
The roller style lifters have a small steel wheel or "roller" at the bottom which rides on the lobes of the cam.
None of the parts between the two are interchangable, these being , cam, lifters, pushrods, as well roller cams need to have what I refer to as a "keeper" at the front that bolts to the block to keep the cam from "walking" or moving forward out of alignment.
Flat tappet cams do not need this.
The reason you can choose between the two set ups is because your year block more than likely has tapped holes in the front of your block where the cam slides in to bolt on the keeper ring for the roller cam.
"I don't know how better to explain this last part so I hope this makes sence"
I suppose the best argument for going "roller" would longevity, a wheel rolling on the lobes of the cam would cause much less wear, heat and friction than the flat surface rubbing on the cam lobes of the flat tappet style.
The timing chain for either is the same, though if doing a cam swap I would advise changing the chain and gears if stock, if only because everything is already opened up and ready to do so, chain and gears are cheap.
The "roller" in roller timing chain has nothing to do with your valve train in the way you may be thinking.
The "roller" in this instance refers to the chain itself, the pins that hold the chain links together are what ride on the gears, in the roller style these pins are surrounded by a tube that roles on the pins, "here again less friction", as well you avoid having the same point on the pin rubbing the same point on the gears over and over as the assembly rotates reducing metal on metal wear, heat and friction.
Longevity would be the key word here again.
Your choice in setup depend on you, the old flat tappet style are just fine for everyday use.
If building for performance and looking for every pony you can get, go roller.
The one thing I can't stress enough is that whatever setup you choose, follow the " breakin procedure" exactly.
If going flat tappet be sure your engine is ready to run the full 20 min before shutdown, plenty of fuel, water,and get the timing as close as you can, just follow the instructions that come with your cam kit.
I have seen friends lose a cam after only 2 or 3 k just because they did not breakin properly, and this usualy because they were just in to big a hurry to "get the thing fired".
Long post I know but just a line or two really would not explain the questions you asked.
I hope this helps, good luck with your install.
Old 09-11-2006, 09:48 PM
Re: 350 Upgrades
I went ahead and ordered a Lunati Voodoo 60101LK cam and lifter combo. It was a hard debate between that and the 60102LK set....Think i made the right choice?
Also...here are some more parts ive got coming
Performer TBI intake
Holley 502-6 TBI
Mid length headers
Underdrive pulley kit
Old 09-12-2006, 09:45 AM
Blue Bowtie's Avatar
Registered Offender
Re: 350 Upgrades
Before opening the package on the underdrive sheave set (so you cannot return it) you may want to perform a little reseach on the effectiveness of underdrives. While they may reduce parasitic load enough to make a few more HP on engines operating at 5,800 RPM most of the time, the only real difference you may notice on the street is inadequate charging, inadequate cooling, and lack of steering power assist.
Please, don't take my word for it. Do some research.
