Go Back   Automotive Forums Car Chat > Saturn > Ion
Old 09-09-2006, 07:54 PM
saturnsucks saturnsucks is offline
2006 Ion Won't start sometime's, then will later.
2006 Saturn Ion won't start sometime's then a while later it starts just fine. The battery is fine, plenty of gas and there is no apparent explanation. All features still work w/ key in accesory position, even the fan runs for the AC. But when you try to start it, nothing... not even the starter clicking or trying to turn over. Then, an hour or so later it's fine. Any ideas?
Old 09-09-2006, 11:21 PM
PlayStation3 PlayStation3 is offline
Re: 2006 Ion Won't start sometime's, then will later.
get your alternator checked. my sl2 does that and it was found that my alternator was going and sometimes would not have enough power to take over the electrical stystem
Old 09-11-2006, 06:06 AM
HAWG HAWG is offline
you need a new ignition switch. Have it checked out. It should still be under warranty.
Old 09-23-2006, 06:38 PM
redline2004guy redline2004guy is offline
Has anyone in here upgraded their redline with a stage 2 or 1 kit if so how much did it cost u for the kit and install?
Old 11-09-2006, 06:48 PM
one_der one_der is offline
ion tsk tsk tsk tsk tsk.
Old 11-22-2006, 09:40 AM
travist's Avatar
travist travist is offline
The ignition switch and BCM are causing the problem. There is a bulletin out for this a would be under mfg warr.
Old 02-14-2010, 12:31 AM
VTISC007 VTISC007 is offline
Just wondering,,,what's a BCM??? thanx
2004 Chevrolet 2500 HD 4X4
1988 Toyota 4Runner
2000 Yamaha R1
1998 Yamaha WR400
1990 Honda CRX
Old 10-22-2013, 10:09 PM
jokersfb jokersfb is offline
http://moontaj.com/passlock check this out.
