Go Back   Automotive Forums Car Chat > Nissan > Altima
Old 09-09-2006, 07:46 PM
johnkamilo johnkamilo is offline
bad idle
this problem started a week ago. the rpm on the car is jumpin and it seems like the car wants to stall but it wont. when i turn on the a/c on the car the problems seems to go away. i already changed the pcv valve, sparkplug wires, fuel filter, distributor cap and rotor, and the problem is still there. today i got a egr valve at a junk from a 96 model and i didnt see any difference when i put it in the car. has anyone had this problem before?
Old 09-10-2006, 08:46 AM
FixUrNissan's Avatar
FixUrNissan FixUrNissan is offline
Re: bad idle
did you Try spraying Carb Cleaner around the intake manifold to check for leaks?
Old 09-11-2006, 06:40 AM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
Re: bad idle
Get an O2 Sensor. That might be the problem.
Old 09-11-2006, 03:30 PM
Re: bad idle
no an O2 sensor is not going to give it a bad idle!! If he had a Bad O2 sensor he would have a code for it. I am assuming he doesn't have a check engine light. If he does he would know if it was an O2 , If he has a code Po304 Cyl#4 miss fire , then thats definitely a Intake gasket
Old 09-13-2006, 08:20 PM
Re: bad idle
i got my codes checked today at a advanced auto parts and the it says that is a random missfire.... does it have to be cylinder #4 to be the intake manifold gasket.... or can it be any cylinder missfire..... i think the code that i got was po300
