Old 09-09-2006, 01:00 PM
Xalis Xalis is offline
Cooling fan not working in 95 sunfire
My cooling fan will not come on when my car gets hot in my 95 sunfire. The fan will turn on if I jump it at the relay. So it cant be the fan, and cant be the power to the relay. Also if i take the cover off the relay and close the circuit manually the fan will also run. So im guessing what ever makes the relay complete the circuit is damaged. Im gonna read into relays a bit more but does anyone have any idea what I can do?
Old 09-11-2006, 03:07 PM
Re: Cooling fan not working in 95 sunfire
help anyone?
Old 09-11-2006, 03:11 PM
my99cavy's Avatar
my99cavy my99cavy is offline
Send a message via AIM to my99cavy Send a message via MSN to my99cavy
sounds like a bad relay to me try replacing it.
Old 09-11-2006, 08:28 PM
millrtime millrtime is offline
could be a bad thermostat also. cavs/sunfires are notorious for having shitty thermostats. and if its not that, then i would check the relay. good luck, sounds like a lot of fun........
Old 09-11-2006, 09:09 PM
Its not the relay, ive tried several different ones, and its not the thermostat because i just replaced it.
Old 09-13-2006, 09:14 AM
highhopesforcars highhopesforcars is offline
Send a message via Yahoo to highhopesforcars
Sounds like a bad temperature switch to me its usally on the head near the water outleat to the radiator. I have see nthat a lot lately. Find it and unplug it the fan should come on. If it dose then the switch is bad. the car will co in to open loop and cause the fan to stay to protect its self. The key has to be in the on position though.
Old 09-13-2006, 12:52 PM
Thanks a bunch. ill do that
