Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 09-09-2006, 12:16 PM
dws_dws dws_dws is offline
changing wheel studs help
i need to know how to change the fron wheel studs on a 92 lebaron sedan.
thanks
Old 09-09-2006, 01:04 PM
Joric theredbaron's Avatar
Joric theredbaron Joric theredbaron is offline
Re: changing wheel studs help
just the studs or the hub they sit on..??
If it just the studs knock em outta the hub... tap new ones in
or..
you have to drop the brake calipers, steering, upper an lower control arms etc, and split the hub from the knuckle and replace the hub.. and bearings reassemble and tadaa..
Joric
Friends dont let friends drive imports
Old 09-09-2006, 03:13 PM
its just the studs, i broke 3 while trying to change the spare. so i can just hammer the out and hammer in new ones?
Thanks
Old 09-09-2006, 04:51 PM
Hopefully you can do it with the hub in situ.. oh.. i forgot to say.. and remove the disc rotor.. They just hammer out and hammer in.. ive only ever done it x2.. on a ford and a vw (bro in law was heavy handed and turnin lugs wrong way).. check it out.. you'll find the easiest way.. good luck m8..
Joric
