Old 09-09-2006, 12:12 PM
Hola Hola is offline
Radio Antena
I have a Buick LeSabre 1993 with a couple of problems. One is the radio antena, the antena motor never stops making a noise that sounds like it is working to push the antena out, but the antena is laready out. So to stop it I needed to disconected from the conector that is attacthed to the antena insaide the trunk. If I conect it again the motor starts runing again, so I keep it disconected. If any one can help, please let me know.
The other problem is when I was vacuming one day I discovered that the carpet was a little bit wet, so I lifted the edge of the carpet by removing one of the trims and the floor of the car was wet. If any one have any ideas as to where to start fixing this problem, please let me know. I really appreciate any help on any of these two prblems.
Old 09-09-2006, 07:08 PM
grcore grcore is offline
Re: Radio Antena
I never took apart a power antenna assembly, but it sounds like the limit switch is not being tripped.
As far as wet carpet goes, if its the passenger side, I would suspect the heater core or condensation from the evaporator.
Old 09-09-2006, 09:04 PM
imidazol97 imidazol97 is offline
AF -Advisor
Re: Radio Antena
My 93 had the power antenna keep running. The cable inside had broken I was told. Fix is to buy a stationary replacement or get another new or get a ppower antenna from a recycling yard. I chose to keep it disconnected.
Old 09-10-2006, 09:55 AM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Re: Radio Antena
For the antenna, try swapping out the relay that's attached to it. A bad relay can keep the circuit closed, thus leaving the motor running. Depending on what side the water was found, trying getting inside and have someone outside spray the car with a water hose, you may find the leak that way. I did that once before in a 97' Silverado. Sounds like you have a bad weather strip seal around a door.
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
Old 09-12-2006, 06:44 PM
Re: Radio Antena
Thanks everyone for the inputs, I will try them all. I appreciated it very much.
