Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 09-09-2006, 09:40 AM
lalojamesliz lalojamesliz is offline
1969 mustang
can somebody tell me what kind of differential fluid i need to put
? someone told me it might have..... whale fat!!!!!
Old 09-10-2006, 03:59 AM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Re: 1969 mustang
Open or Limited Slip?
Whale fat
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 09-10-2006, 04:00 PM
Re: 1969 mustang
dont know....if i raise the rear and spin one tire and the other side spins the opposite what is that
Old 09-11-2006, 02:17 PM
SkylineUSA's Avatar
Re: 1969 mustang
If you do a burn out, does one tire leave a make, or two? If is two, then you have a limited slip.
I run 90wt synthetics in my rear diffs. If its a limited slip, you have to run an additive for the clutches. There are some 90wt that already have the additives, but you have to make sure you get the right oil.
Old 09-11-2006, 04:51 PM
Re: 1969 mustang
thank you
Old 09-12-2006, 03:56 AM
SkylineUSA's Avatar
Re: 1969 mustang
You're more than welcome.
Any more questions, fire away. There are some pretty knowledgeable guys on here.
Old 09-18-2006, 10:38 PM
Re: 1969 mustang
ok how about this question... how do i change it? it has no drain plug and no back plate just a fill plug or check plug whatever its called.
