Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-09-2006, 09:28 AM
eclipsed at 3am eclipsed at 3am is offline
Send a message via MSN to eclipsed at 3am
Mystery part in engine
I figured I would put this in problem diagnosis, seeing as how im having a problem identifying this part. lol.
One of the lines from my boost controller came loose last night, so i was putting it back on today. Then I was poking around the engine just looking at different things. I dont get much time in the bright daylight to look at the car or anything. Anyways, I came upon this. It was exactly in this condition, with the hose not attached or anything. Can anyone tell me what it is? Its behind the motor, just under the throttle body. I circled it in white.
eclipsed @ 3am
http://www.cardomain.com/ride/2505283
Old 09-09-2006, 09:53 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Mystery part in engine
Looks like the EGR valve. Top of mine looks exactly the same. Same shape and has the little vacuum hose coming out of it. Mine fell off once (no clue how) and it threw a CEL.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 09-09-2006, 02:50 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Yep EGR, don't need it, it's for emissions.
1991 GSX 2.3 Stroker
Old 09-09-2006, 03:16 PM
I dunno if its just psychological, but plugging it back on and ziptying it seemed to make my car run a little smoother. hmm...cant hurt though right?
eclipsed @ 3am
Old 09-09-2006, 06:57 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
A more clear picture would help. David, he's running a 4g63 and it's quite a bit different. But definitely keep it plugged in, but give us a more clear picture.
95 Talon TSI AWD
97 Eclipse GST
Old 09-09-2006, 08:20 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
EGR will make your car run smoother, I remember learning it but it causes a rough idle after warmed up but not at WOT.
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 09-09-2006, 10:34 PM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
Unless you have dsmlink I blocked mine off like alot of people and did away with a shit load of vacumme lines
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
Old 09-10-2006, 12:11 AM
david-b's Avatar
Dave is THAT guy
I know he is. You can still tell its the EGR valve though. The system itself is still the same too.
75 Monte Carlo
Old 09-10-2006, 12:43 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
When thatline was disconnected it could have been making your car run shitty for 2 reasons, first that would be a boost leak, not huge but even a small one can have a negative effect, second it could have caused your car to go into "safe mode" because an emmisions control system wasn't working basically the ecu makes the car run shitty so you can limp it to the mechanic.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 09-10-2006, 12:52 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Yeah looked like the BOV to me at first and I was like, uhhhhhhh....
Yeah, thats your EGR and replugging it in will make it run better. Congratulations.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 09-10-2006, 08:01 AM
if having the egr unplugged would put it in safe mode, does anything have to be reset, now that ive plugged it back in?
eclipsed @ 3am
Old 09-10-2006, 09:42 AM
david-b's Avatar
Dave is THAT guy
It's usually just good to reset the ECU just in case. Disconnect the neg(-) battery and let it sit for 10 minutes. Should get everything fine then
75 Monte Carlo
Old 09-10-2006, 12:08 PM
Thor06's Avatar
Jizzed In My Pants
Doesnt it actually only take like 10 seconds? Cant hurt to let it sit longer though.
Old 09-10-2006, 12:16 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
I can't wait to see all the problems I get from everything I've removed. lol
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 09-10-2006, 12:46 PM
taking off that battery cable like that wont affect the safc would it?
eclipsed @ 3am
