Go Back   Automotive Forums Car Chat > Mercury > Cougar
Old 09-09-2006, 08:30 AM
nhra55314 nhra55314 is offline
1992 Cougar Idle Question
I have a 1992 Cougar LS with the 3.8 V6 and would like to get the Idle up a little higher. I would appreciate any help. Thanks
Old 09-10-2006, 11:53 AM
samturner samturner is offline
Re: 1992 Cougar Idle Question
Looking at the engine from the front you should be able to see where the accelerator cable hooks on to the throttle shaft. Right behind that and a little above you should see a hex head bolt that is slotted for a screw driver. This should adjust your idle.
You might want to check the air filter and PCV valve at the least before changing it
