Go Back   Automotive Forums Car Chat > Mazda > B-Series/Bravo/Bounty/Drifter
B-Series/Bravo/Bounty/Drifter Bravo is the Australian vesion, Bounty the New Zealand version and Drifter the South African version.
Old 09-09-2006, 08:24 AM
sprcivic82 sprcivic82 is offline
holley 5200 prob
i have a holley 5200 off a pinto on my 87 b2600. as a side note i have had a weber on there also and it did the same thing to me. the truck will start fine, idle fine, as soon as you start to give it any gas it will rev up and when you get to about 2000 rpm it will start to spit gas out of the primary shaft and start to bog down and then when the secondary starts to open it bogs way down and dies. i thought maybe it was to much fuel from factory pump so i regulate it down to 2.5 and that is not enough gas. i am stumped. please help.
Old 09-10-2006, 10:17 AM
hocbj23 hocbj23 is offline
Re: holley 5200 prob
Check the vacuum advance on your distributer.Sounds like it is not pulling around and advancing as it should,truck bogs down and spits fuel out the carb.MAybe bad vac hose on dist needs to be replaced.BJ
Old 09-10-2006, 09:01 PM
well that was not it. i replaced the hose and it still does the same thing. i am stumped still, i gotta get the trash to the dump but this thing wont run right.
Old 09-10-2006, 10:11 PM
ChoochCharlie's Avatar
ChoochCharlie ChoochCharlie is offline
Sounds like you have clogged Catalytic Converters like mine.
You can remove the pipe from the bottom of the front cat and dump a bunch of debris. I still need to empty the debris from the second cat and muffler too.
Old 09-12-2006, 08:14 PM
that was perfect. i took the second cat off. well cut the bolts off and dumped the cat and alot of stuff fell out. so i busted the rest of it out since we dont have to go through emissions here in oregon. left the cat off. started it. reved up the motor. no gas, no stalling. now just to put it back on and go for it. thanks guys.
